Webserver (Web UI/API) *
may only be installed on one server (however, some can be clustered)
How can you do distributed polling and disable the web UI or not have the web UI installed?
Hello! This Video right here helped me out with creating a distributed polling set up. LibreNMS Distributed Polling - YouTube
I believe once you have everything installed on your main LibreNMS instance and you start building the Poller , you can skip the NGINX webserver portion of the installation and you won’t have the web UI on the Poller.
I moved the memcached configurations to the config.php instead of using the WEB ui and it appears to be working now without nginx.
