So, I’ve got two systems that are on another location, and the hosting company doesn’t like the port 161 being open. I discovered the distributed poller and got it working, it’s all set up.
However, I’ve added the two machines to a seperate poller_group, because snmp doesn’t work for the machines as the port isn’t open. I was struggeling with it, because no matter what I do, the WebUI only shows the “default poller group”. I know for sure there are machines in the group 0 (default) and the two other machines are in group 1.
I looked through the database and the hosts were in the database as group 0, even though I changed it in the config file.
I’ve since manually edited the database entry, and after a few minutes it seems like the poller-wrapper on the distributed poller host is running correctly now (it was not polling any machine), but the web UI still only shows the default group…
Edit:
output of ./validate.php on the main machine:
LibreNMS | 8d5c3f34f2117c27ee76c0a129c9634a8f065982
DB Schema | 195
PHP | 7.0.18-0ubuntu0.17.04.1
MySQL | 10.1.22-MariaDB-
RRDTool | 1.6.0
SNMP | NET-SNMP 5.7.3
Output of ./validate on the distributed poller machine:
DB Schema | 195
PHP | 5.6.30-0+deb8u1
RRDTool | 1.6.0
SNMP | NET-SNMP 5.7.2.1
Any tips?
