I have two VM with librenms full setup configured and running with rrdcached. Now I want to enable distributed polling between them.
I have gone through the manual https://docs.librenms.org/Extensions/Distributed-Poller/
Following is the sample configuration
1st node
$config['distributed_poller_name'] = librenms-node1;
$config['distributed_poller_group'] = '0';
$config['distributed_poller_memcached_host'] = "librenms-node1";
$config['distributed_poller_memcached_port'] = 11211;
$config['distributed_poller'] = true;
$config['rrdcached'] = "librenms-node1:42217";
Second node
$config['distributed_poller_name'] = librenms-node2;
$config['distributed_poller_group'] = '1';
$config['distributed_poller_memcached_host'] = "librenms-node2";
$config['rrdcached'] = "librenms-node2:42217";
Can anyone please confirm whether anyone will this configuration work ?
Thanks in advance
