The output of ./validate.php
webserver:
| LibreNMS | 22.7.0-36-gb12400861 |
| DB Schema | 2022_07_19_081224_plugins_unique_index (244) |
| PHP | 7.4.30 |
| Python | 3.9.2 |
| Database | MariaDB 10.5.15-MariaDB-0+deb11u1 |
| RRDTool | 1.7.2 |
| SNMP | 5.9 |
[OK] Composer Version: 2.3.10
[OK]
[OK] MySQl and PHP time match
[WARN] PHP version 8.1 is the minimum supported version as of September, 2022. We recommend you update PHP to a supported version (8.1 suggested) to continue to receive updates. If you do not update PHP, LibreNMS will continue to function but stop receiving bug fixes and updates.
[FAIL] Missing PHP extension: memcached
Please install memcached
[OK] No active python wrapper pollers found
[OK] Redis is functional
poller01:
| PHP | 7.4.30 |
| Python | 3.9.2 |
| RRDTool | 1.7.2 |
| SNMP | 5.9 |
[OK]
Modified Files:
bootstrap/cache/.gitignore
config.php.default
logs/.gitignore
rrd/.gitignore
storage/app/.gitignore
storage/app/public/.gitignore
storage/debugbar/.gitignore
storage/logs/.gitignore
poller02:
| PHP | 7.4.30 |
| Python | 3.9.2 |
| RRDTool | 1.7.2 |
| SNMP | 5.9 |
[OK]
Modified Files:
config.php.default
poller03:
| PHP | 7.4.30 |
| Python | 3.9.2 |
| RRDTool | 1.7.2 |
| SNMP | 5.9 |
[OK]
Modified Files:
config.php.default
I am using the Dispatcher service and i have disables all cronjobs according to:
https://docs.librenms.org/Extensions/Dispatcher-Service/#cron-scripts
But when i disable the cronjob, all the pollers become red in de Poller page in the WebGUI:
The last checkin, in the Poller Cluster Health, shows the correct time when the polling has finished, but in the Standard pollers sections, all pollers becomes red. How can i fix this, or can i delete them because i am using the distributed polling setup?
Thanks in advance!
