$ ./validate.php
| LibreNMS | 23.2.0-31-g68e0b3df2 (2023-03-13T22:32:22+01:00) |
| DB Schema | 2022_08_15_084507_add_rrd_type_to_wireless_sensors_table (248) |
| PHP | 8.1.11 |
| Python | 3.9.15 |
| Database | MariaDB 10.5.15-MariaDB |
| RRDTool | 1.8.0 |
| SNMP | 5.9.1 |
[OK] Composer Version: 2.5.4
[OK] MySQl and PHP time match
SQL[SELECT COUNT(*) FROM
sensorsWHERE device_id = ? ANDsensor_class= ? ANDsensor_type= ‘cisco-entity-sensor’ ANDsensor_index= ? [24104,“voltage”,25003] 0.83ms]SQL[SELECT COUNT(*) FROM
sensorsWHERE device_id = ? ANDsensor_class= ? ANDsensor_type= ‘cisco-entity-sensor’ ANDsensor_index= ? [24104,“voltage”,25004] 0.81ms]SQL[SELECT COUNT(*) FROM
sensorsWHERE device_id = ? ANDsensor_class= ? ANDsensor_type= ‘cisco-entity-sensor’ ANDsensor_index= ? [24104,“voltage”,25005] 0.81ms]SQL[SELECT COUNT(*) FROM
sensorsWHERE device_id = ? ANDsensor_class= ? ANDsensor_type= ‘cisco-entity-sensor’ ANDsensor_index= ? [24104,“voltage”,25006] 0.8ms]Error discovering sensors module for ******. DivisionByZeroError: Division by zero in /usr/opt/librenms/includes/discovery/sensors/entity-sensor.inc.php:140
Stack trace:
#0 /usr/opt/librenms/includes/discovery/sensors.inc.php(16): require()
#1 /usr/opt/librenms/includes/discovery/functions.inc.php(153): include(‘/usr/opt/libren…’)
#2 /usr/opt/librenms/discovery.php(106): discover_device(Array, true)
#3 {main}
SQL[insert intoeventlog(reference,type,datetime,severity,message,username,device_id) values (?, ?, ?, ?, ?, ?, ?) [null,“discovery”,“2023-03-14 09:56:43”,5,“Error discovering sensors module. Check log file for more details.”,“”,24104] 0.48ms]Division by zero {“exception”:“[object] (DivisionByZeroError(code: 0): Division by zero at /usr/opt/librenms/includes/discovery/sensors/entity-sensor.inc.php:140)”}
// LOG //
[2023-03-14T09:56:43.166646+01:00] production.ERROR: Error discovering sensors module for ******. DivisionByZeroError: Division by zero in /usr/opt/librenms/includes/discovery/sensors/entity-sensor.inc.php:140
Stack trace:
#3 {main}
[2023-03-14T09:56:43.171221+01:00] production.ERROR: Division by zero {“exception”:“[object] (DivisionByZeroError(code: 0): Division by zero at /usr/opt/librenms/includes/discovery/sensors/entity-sensor.inc.php:140)”}
objectID 25003 to 25006 ok!
25007 fails…
snmpwalk:
entPhySensorType.25003 = voltsDC
entPhySensorType.25004 = voltsDC
entPhySensorType.25005 = voltsDC
entPhySensorType.25006 = voltsDC
entPhySensorType.25007 = voltsDC
entSensorValue.25003 = 4984
entSensorValue.25004 = 3288
entSensorValue.25005 = 1794
entSensorValue.25006 = 12045
entSensorValue.25007 = 4959
entPhySensorScale.25003 = yocto
entPhySensorScale.25004 = yocto
entPhySensorScale.25005 = yocto
entPhySensorScale.25006 = yocto
entPhySensorScale.25007 = zepto
25003 =>
array (
‘entSensorType’ => ‘voltsDC’,
‘entSensorScale’ => ‘yocto’,
‘entSensorValue’ => ‘4984’,
‘entSensorMeasuredEntity’ => ‘25000’,
‘entSensorPrecision’ => ‘0’,
25004 =>
array (
‘entSensorValue’ => ‘3288’,
25005 =>
array (
‘entSensorValue’ => ‘1794’,
25006 =>
array (
‘entSensorValue’ => ‘12045’,
25007 =>
array (
‘entSensorScale’ => ‘zepto’,
‘entSensorValue’ => ‘4959’,
→ /usr/opt/librenms/includes/discovery/sensors/entity-sensor.inc.php
$type = $entitysensor[$entry['entPhySensorType']];
// FIXME this stuff is foul
if ($entry['entPhySensorScale'] == 'nano') {
$divisor = '1000000000';
$multiplier = '1';
if ($entry['entPhySensorScale'] == 'micro') {
$divisor = '1000000';
$multiplier = '1';
if ($entry['entPhySensorScale'] == 'milli') {
$divisor = '1000';
$multiplier = '1';
if ($entry['entPhySensorScale'] == 'units') {
$divisor = '1';
$multiplier = '1';
if ($entry['entPhySensorScale'] == 'kilo') {
$divisor = '1';
$multiplier = '1000';
if ($entry['entPhySensorScale'] == 'mega') {
$divisor = '1';
$multiplier = '1000000';
if ($entry['entPhySensorScale'] == 'giga') {
$divisor = '1';
$multiplier = '1000000000';
if ($entry['entPhySensorScale'] == 'yocto') {
$divisor = '1';
$multiplier = '1';
zepto is missing!
