louis
21 January 2020 10:23
1
Currently alert timestamp changes when alert is acknowledged. This is a misleading behaviour as we cannot know when the real timestamp of the alert. This PR fixes this behaviour.
Anyone to test the fix ?
librenms:master ← louis-6wind:alert-reappear
opened 03:09PM - 05 Dec 19 UTC
DO NOT DELETE THIS TEXT
#### Please note
> Please read this information ca… refully. You can run `./scripts/pre-commit.php` to check your code before submitting.
- [X] Have you followed our [code guidelines?](http://docs.librenms.org/Developing/Code-Guidelines/)
#### Testers
After you are done testing, you can remove the changes with `./scripts/github-remove`. If there are schema changes, you can ask on discord how to revert.
To apply:
./scripts/github-apply 10907
To revert:
./scripts/github-remove -d
