Hi all -
Having a real headache getting the official LibreNMS Docker container to work with the example config - I’m running Centos7 on ESXi and have disabled selinux for now.
I followed the Docker Compose instructions here to the letter:
https://github.com/librenms/docker/blob/master/doc/usage.md
I left all of the example file contents as they were, hoping that everything would at least start up (without the correct hostname etc), but I can’t get the web UI to load.
docker-compose logs | grep error doesn’t show any errors - here are the last few lines (guessing the SMTP_PASSWORD messages are not fatal to the app as a whole):
db_1 | 2020-04-28 19:05:35 140533594838784 [Note] InnoDB: Buffer pool(s) load completed at 200428 19:05:35
librenms | Nothing to migrate.
librenms | [cont-init.d] 04-svc-main.sh: exited 0.
librenms | [cont-init.d] 05-svc-cron.sh: executing...
librenms | [cont-init.d] 05-svc-cron.sh: exited 0.
librenms | [cont-init.d] 06-svc-syslogng.sh: executing...
librenms | [cont-init.d] 06-svc-syslogng.sh: exited 0.
librenms | [cont-init.d] done.
librenms | [services.d] starting services
librenms | 2020/04/28 19:05:35 [notice] 318#318: using the "epoll" event method
librenms | 2020/04/28 19:05:35 [notice] 318#318: nginx/1.16.1
librenms | 2020/04/28 19:05:35 [notice] 318#318: OS: Linux 3.10.0-1127.el7.x86_64
librenms | 2020/04/28 19:05:35 [notice] 318#318: getrlimit(RLIMIT_NOFILE): 1048576:1048576
librenms | 2020/04/28 19:05:35 [notice] 318#318: start worker processes
librenms | 2020/04/28 19:05:35 [notice] 318#318: start worker process 325
librenms | [services.d] done.
librenms | [28-Apr-2020 19:05:35] NOTICE: fpm is running, pid 316
librenms | [28-Apr-2020 19:05:35] NOTICE: ready to handle connections
librenms_smtp exited with code 1
smtp_1 | SMTP_PASSWORD is not set
cron_1 | crond: USER librenms pid 320 cmd /opt/librenms/alerts.php >> /dev/null 2>&1
librenms | OMITTED - - [28/Apr/2020:19:06:46 +0200] "GET / HTTP/1.1" 302 386 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:75.0) Gecko/20100101 Firefox/75.0"
librenms | OMITTED - - [28/Apr/2020:19:06:46 +0200] "GET /login HTTP/1.1" 200 2401 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:75.0) Gecko/20100101 Firefox/75.0"
Port 8000 is listening (assuming that’s what I should connect to to see the LibreNMS GUI?):
netstat -plant
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 127.0.0.1:25 0.0.0.0:* LISTEN 1619/master
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 1068/sshd
tcp 0 36 OMITTED:22 OMITTED:25688 ESTABLISHED 12010/sshd: root@pt
tcp6 0 0 ::1:25 :::* LISTEN 1619/master
tcp6 0 0 :::8000 :::* LISTEN 20091/docker-proxy
tcp6 0 0 :::514 :::* LISTEN 20570/docker-proxy
tcp6 0 0 :::22 :::* LISTEN 1068/sshd
Navigating to http://OMITTED:8000 redirects to OMITTED/login and the page doesn’t load (presumably because nothing is listening on TCP 80). I am seeing some 200 HTTP response codes in the log (see above).
Running containers:
docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
382f1508f001 librenms/librenms:latest "/init" 16 minutes ago Up 3 minutes 514/tcp, 8000/tcp, 514/udp librenms_cron
a7c183cb5203 librenms/librenms:latest "/init" 16 minutes ago Up 3 minutes 0.0.0.0:514->514/tcp, 0.0.0.0:514->514/udp, 8000/tcp librenms_syslog
b2d71f2126f2 librenms/librenms:latest "/init" 16 minutes ago Up 3 minutes 514/tcp, 514/udp, 0.0.0.0:8000->8000/tcp librenms
a173db1e5aca crazymax/rrdcached "/entrypoint.sh /usr…" 16 minutes ago Up 3 minutes (healthy) 42217/tcp librenms_rrdcached
9f171c76a1e8 juanluisbaptiste/postfix "/run.sh" 16 minutes ago Restarting (1) 7 seconds ago librenms_smtp
811239db7d04 mariadb:10.2 "docker-entrypoint.s…" 16 minutes ago Up 3 minutes 3306/tcp librenms_db
14458bfdc2e4 memcached:alpine "docker-entrypoint.s…" 16 minutes ago Up 3 minutes 11211/tcp librenms_memcached
Docker version: 19.03.8, build afacb8b
Have I missed anything obvious? I tried messing around with the traefik example and got a little further (it would display 404 errors, which showed the web server was running) but again, couldn’t get the UI to load.
Any help would be gratefully received.
