Hi
How can i resolve the permissions issue below in the docker deployment for librebms
librenms | PHP Warning: imagepng(weathermap.png): failed to open stream: Permission denied in /opt/librenms/html/plugins/Weathermap/lib/Weathermap.class.php on line 3321
librenms | WARNING: configs//another.conf: Failed to create image file weathermap.png - permissions of output directory are wrong? [WMWARN14]
librenms | PHP Deprecated: The each() function is deprecated. This message will be suppressed on further calls in /opt/librenms/html/plugins/Weathermap/lib/Weathermap.class.php on line 778
librenms | WARNING: configs//weathermap: Failed to create image file weathermap.png - permissions of output directory are wrong? [WMWARN14]
librenms | WARNING: configs//Test.conf: ReadData: LINK switch-firewall, target: ./192.168.2.1/port-id1.rrd:INOCTETS:OUTOCTETS on config line 60 of configs//Test.conf had no valid data, according to WeatherMapDataSource_rrd
librenms | WARNING: configs//Test.conf: ReadData: LINK firewall-node08317, target: ./192.168.2.21/port-id132.rrd:INOCTETS:OUTOCTETS on config line 66 of configs//Test.conf had no valid data, according to WeatherMapDataSource_rrd
