Dr.Neuhaus Device (Sagemcom) no sysName
I have just created a driver for the product Dr.Neuhaus. However, I have a small problem with the device name.
Unfortunately, Dr.Neuhaus does not fill the sysName but uses its own description entry in the private MIB for this purpose.
Is there a way to use this entry to display sysName? The same would also be the case with the location.
Thanks for the help!
Kind regards
