SNMP[[0;36m/usr/bin/snmpget -v2c -c COMMUNITY -OQUs -m UCD-SNMP-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/hp udp:HOSTNAME:161 laLoadInt.1 laLoadInt.2 laLoadInt.3[0m]
laLoadInt.1 = No Such Object available on this agent at this OID
laLoadInt.2 = No Such Object available on this agent at this OID
laLoadInt.3 = No Such Object available on this agent at this OID
Your device isn’t returning the data, ensure you aren’t restricting any snmp options in snmpd.conf (see our example file included in your install).
Unfortunately the snmpd.conf is the same as of that in the example config (minus the change to the “RANDOMSTRINGGOESHERE” which is now the community string).
So I guess the switches just won’t output the ucd_load data and there’s nothing I can do about it?
