The Ports Page is reporting 0mpbs on all dsl ports. Is it possible to report DSL speeds?
please post out put of validate.php
Also what device are you talking about?
Calix B6-252 is the device.
| LibreNMS | 1.31.03-27-g455c721 |
| DB Schema | 206 |
| PHP | 7.0.22-0ubuntu0.16.04.1 |
| MySQL | 10.0.31-MariaDB-0ubuntu0.16.04.2 |
| RRDTool | 1.5.5 |
| SNMP | NET-SNMP 5.7.3 |
librenms@librenms:~$
That’s because your device isn’t sending valid data then for the standard IF-MIB, you really should go shout at the vendor.
If they have a MIB for interface info, we might be able to add support but you’ll need to provide the MIB + a full snmpwalk.
I can get with the vendor, just wasn’t sure if it was because of it being a DSL port that uses ATM that was causing the issue. The MIBS are attached to the new device request. I had trouble getting this device to do a complete snmpwalk, it kept timing out but will give it another shot. Thanks for all your help and time!
Here is the link to the snmpwalk - https://drive.google.com/open?id=0B1FweAkoUX92cWFrT09raUV0c00.
The Mibs are with the device request : New Device Request Calix B6-252 · Issue #7293 · librenms/librenms · GitHub.
I have attached some screenshots. The one with the ethernet bandwidth info was added before the b6 request.
The other 1 is from a b6 added after the device add request.
