Dave
4 August 2023 21:29
1
Howdy,
My daily.sh is failing, below is the output - Does anyone have any ideas on this?
Cheers
~$ ./daily.sh
Updating Composer packages OK
Updated from d810c7a64 to de65ff55f OK
Updating SQL-Schema FAIL
INFO Running migrations.
2023_08_02_090027_drop_dbschema_table … 962ms DONE
2023_08_02_120455_vendor_ouis_unique_index … 3,611ms FAIL
In Connection.php line 795:
SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry ‘000000’ for key ‘vendor_ouis_oui_unique’ (Connection:
mysql, SQL: alter table vendor_ouis add unique vendor_ouis_oui_unique(oui))
In Connection.php line 580:
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
got the same thing here.
Do you really wish to run this command? (yes/no) [no]
❯ y
2023_08_02_120455_vendor_ouis_unique_index … 126ms FAIL
SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry ‘000000’ for key ‘vendor_ouis_oui_unique’ (Connection: mysql, SQL: alter ta
dang me too
2023_08_02_120455_vendor_ouis_unique_index … 80ms FAIL
Scary to have duplicates in that table, it is a large table!
Just truncate the vendor_ouis table, then run the migration. (A fix was merged that does this for you)
If you want to repopulate the MAC vendors, run lnms maintenance:fetch-ouis
system
Closed
3 November 2023 02:36
5
