This appears to still be a problem; I’m using the latest clone from today. I also tried the “kludge” above but that in turn breaks the audit log and throws a different error.
It doesn’t matter what rights the user has, the error is always the same:
Here’s config.php:
$config[‘http_auth_guest’] = “Operations”;
$config[‘auth_mechanism’] = “http-auth”;
I’ve also tried it with ‘admin’ and ‘Admin’ but the results are the same:
[2020-03-16 14:33:21] production.ERROR: SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry ‘http-auth-Operations’ for key ‘username’ (SQL: insert into users (descr, realname, email, username, auth_type, auth_id, level, can_modify_passwd, enabled, updated_at, created_at) values (, , [email protected], Operations, http-auth, 9, 5, 1, 1, 2020-03-16 14:33:21, 2020-03-16 14:33:21)) {“exception”:"[object] (Illuminate\Database\QueryException(code: 23000): SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry ‘http-auth-Operations’ for key ‘username’ (SQL: insert into users (descr, realname, email, username, auth_type, auth_id, level, can_modify_passwd, enabled, updated_at, created_at) values (, , [email protected], Operations, http-auth, 9, 5, 1, 1, 2020-03-16 14:33:21, 2020-03-16 14:33:21)) at /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php:664, Doctrine\DBAL\Driver\PDOException(code: 23000): SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry ‘http-auth-Operations’ for key ‘username’ at /opt/librenms/vendor/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php:119, PDOException(code: 23000): SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry ‘http-auth-Operations’ for key ‘username’ at /opt/librenms/vendor/doctrine/dbal/lib/Doctrine/DBAL/Driver/PDOStatement.php:117)
[stacktrace]
#0 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php(624): Illuminate\Database\Connection->runQueryCallback()
#1 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php(459): Illuminate\Database\Connection->run()
#2 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php(411): Illuminate\Database\Connection->statement()
#3 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Query/Processors/Processor.php(32): Illuminate\Database\Connection->insert()
#4 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Query/Builder.php(2690): Illuminate\Database\Query\Processors\Processor->processInsertGetId()
#5 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Builder.php(1353): Illuminate\Database\Query\Builder->insertGetId()
#6 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Model.php(839): Illuminate\Database\Eloquent\Builder->__call()
#7 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Model.php(804): Illuminate\Database\Eloquent\Model->insertAndSetId()
#8 /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Eloquent/Model.php(667): Illuminate\Database\Eloquent\Model->performInsert()
#9 /opt/librenms/app/Providers/LegacyUserProvider.php(213): Illuminate\Database\Eloquent\Model->save()
#10 /opt/librenms/vendor/laravel/framework/src/Illuminate/Auth/SessionGuard.php(349): App\Providers\LegacyUserProvider->retrieveByCredentials()
#11 /opt/librenms/app/Http/Middleware/LegacyExternalAuth.php(36): Illuminate\Auth\SessionGuard->attempt()
#12 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(163): App\Http\Middleware\LegacyExternalAuth->handle()
#13 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#14 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/VerifyCsrfToken.php(75): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}()
#15 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(163): Illuminate\Foundation\Http\Middleware\VerifyCsrfToken->handle()
#16 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#17 /opt/librenms/vendor/laravel/framework/src/Illuminate/View/Middleware/ShareErrorsFromSession.php(49): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}()
#18 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(163): Illuminate\View\Middleware\ShareErrorsFromSession->handle()
#19 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#20 /opt/librenms/app/Http/Middleware/LoadUserPreferences.php(31): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}()
#21 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(163): App\Http\Middleware\LoadUserPreferences->handle()
#22 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#23 /opt/librenms/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(56): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}()
#24 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(163): Illuminate\Session\Middleware\StartSession->handle()
#25 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#26 /opt/librenms/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/AddQueuedCookiesToResponse.php(37): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}()
#27 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(163): Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle()
#28 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#29 /opt/librenms/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/EncryptCookies.php(66): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}()
#30 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(163): Illuminate\Cookie\Middleware\EncryptCookies->handle()
#31 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#32 /opt/librenms/app/Http/Middleware/CheckInstalled.php(46): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}()
#33 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(163): App\Http\Middleware\CheckInstalled->handle()
#34 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#35 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(104): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}()
#36 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Router.php(682): Illuminate\Pipeline\Pipeline->then()
#37 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Router.php(657): Illuminate\Routing\Router->runRouteWithinStack()
#38 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Router.php(623): Illuminate\Routing\Router->runRoute()
#39 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Router.php(612): Illuminate\Routing\Router->dispatchToRoute()
#40 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(176): Illuminate\Routing\Router->dispatch()
#41 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(30): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}()
#42 /opt/librenms/vendor/darkghosthunter/larapoke/src/Http/Middleware/LarapokeGlobalMiddleware.php(18): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}()
#43 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(163): DarkGhostHunter\Larapoke\Http\Middleware\LarapokeGlobalMiddleware->handle()
#44 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#45 /opt/librenms/vendor/fideloper/proxy/src/TrustProxies.php(57): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}()
#46 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(163): Fideloper\Proxy\TrustProxies->handle()
#47 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#48 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}()
#49 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(163): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#50 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#51 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/TransformsRequest.php(21): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}()
#52 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(163): Illuminate\Foundation\Http\Middleware\TransformsRequest->handle()
#53 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#54 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/ValidatePostSize.php(27): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}()
#55 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(163): Illuminate\Foundation\Http\Middleware\ValidatePostSize->handle()
#56 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#57 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/CheckForMaintenanceMode.php(62): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}()
#58 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(163): Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle()
#59 /opt/librenms/vendor/laravel/framework/src/Illuminate/Routing/Pipeline.php(53): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}()
#60 /opt/librenms/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(104): Illuminate\Routing\Pipeline->Illuminate\Routing\{closure}()
#61 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(151): Illuminate\Pipeline\Pipeline->then()
#62 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(116): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter()
#63 /opt/librenms/html/index.php(53): Illuminate\Foundation\Http\Kernel->handle()
#64 {main}
