Duplicate key name bill_data_bill_id_timestamp_index
Hi Folks,
I am a bit lost and the conversation on GitHub is also not making much progress.
I am a bit concerned about screwing up billing data when doing some uneducated guess
Maybe someone is having an idea how to get it resolved?
Thank you!
sudo -u librenms /opt/librenms/validate.php
Component | Version |
LibreNMS | 24.1.0-68-gd75c80b9b (2024-02-06T20:29:24+01:00) |
DB Schema | 2024_01_09_223917_bill_data_new_primary (287) |
PHP | 8.2.15 |
Python | 3.11.2 |
Database | MariaDB 10.11.6-MariaDB |
RRDTool | 1.7.2 |
SNMP | 5.9.3 |
[OK] Composer Version: 2.6.6
./lnms migrate
Attempt to fix this issue (y or n)?:y
In Connection.php line 822:
SQLSTATE[42000]: Syntax error or access violation: 1061 Duplicate key name ‘bill_data_bill_id_timestamp_index’ (Connection: mysql, SQL: alter table bill_data
add index bill_data_bill_id_timestamp_index
(bill_id
, timestamp
In Connection.php line 580:
sudo -u librenms ./lnms migrate
APPLICATION IN PRODUCTION.
┌ Are you sure you want to run this command? ──────────────────┐
│ Yes │
INFO Running migrations.
2024_01_09_223927_bill_data_updated_indexes … 7ms FAIL
(bill_id
, timestamp
sudo -u librenms /opt/librenms/lnms migrate --force -vvv
SQL[select table_name as name
, (data_length + index_length) as size
, table_comment as comment
, engine as engine
, table_collation as collation
from information_schema.tables where table_schema = ‘libre_db’ and table_type in (‘BASE TABLE’, ‘SYSTEM VERSIONED’) order by table_name 5.95ms]
, engine as engine
from information_schema.tables where table_schema = ‘libre_db’ and table_type in (‘BASE TABLE’, ‘SYSTEM VERSIONED’) order by table_name 5.92ms]
SQL[select migration
from migrations
order by batch
asc, migration
asc 5.21ms]
from migrations
order by batch
asc, migration
asc 2.81ms]
SQL[select max(batch
) as aggregate from migrations
0.65ms]
2024_01_09_223927_bill_data_updated_indexes … 9ms FAIL
(bill_id
, timestamp
)) {“exception”:“[object] (Illuminate\Database\QueryException(code: 42000): SQLSTATE[42000]: Syntax error or access violation: 1061 Duplicate key name ‘bill_data_bill_id_timestamp_index’ (Connection: mysql, SQL: alter table bill_data
(bill_id
, timestamp
)) at /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php:822)
[previous exception] [object] (PDOException(code: 42000): SQLSTATE[42000]: Syntax error or access violation: 1061 Duplicate key name ‘bill_data_bill_id_timestamp_index’ at /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php:580)”}
[Illuminate\Database\QueryException (42000)]
(bill_id
, timestamp
Exception trace:
Illuminate\Database\Connection->runQueryCallback() at /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php:776
Illuminate\Database\Connection->run() at /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php:569
Illuminate\Database\Connection->statement() at /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Schema/Blueprint.php:110
Illuminate\Database\Schema\Blueprint->build() at /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Schema/Builder.php:555
Illuminate\Database\Schema\Builder->build() at /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Schema/Builder.php:397
Illuminate\Database\Schema\Builder->table() at /opt/librenms/vendor/laravel/framework/src/Illuminate/Support/Facades/Facade.php:355
Illuminate\Support\Facades\Facade::__callStatic() at /opt/librenms/database/migrations/2024_01_09_223927_bill_data_updated_indexes.php:14
Illuminate\Database\Migrations\Migration@anonymous/opt/librenms/database/migrations/2024_01_09_223927_bill_data_updated_indexes.php:7$1db->up() at /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php:493
Illuminate\Database\Migrations\Migrator->runMethod() at /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php:410
Illuminate\Database\Migrations\Migrator->Illuminate\Database\Migrations{closure}() at /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php:419
Illuminate\Database\Migrations\Migrator->runMigration() at /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php:216
Illuminate\Database\Migrations\Migrator->Illuminate\Database\Migrations{closure}() at /opt/librenms/vendor/laravel/framework/src/Illuminate/Console/View/Components/Task.php:37
Illuminate\Console\View\Components\Task->render() at /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php:756
Illuminate\Database\Migrations\Migrator->write() at /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php:216
Illuminate\Database\Migrations\Migrator->runUp() at /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php:181
Illuminate\Database\Migrations\Migrator->runPending() at /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php:124
Illuminate\Database\Migrations\Migrator->run() at /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Console/Migrations/MigrateCommand.php:90
Illuminate\Database\Console\Migrations\MigrateCommand->Illuminate\Database\Console\Migrations{closure}() at /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Migrations/Migrator.php:633
Illuminate\Database\Migrations\Migrator->usingConnection() at /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Console/Migrations/MigrateCommand.php:83
Illuminate\Database\Console\Migrations\MigrateCommand->handle() at /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:36
Illuminate\Container\BoundMethod::Illuminate\Container{closure}() at /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/Util.php:41
Illuminate\Container\Util::unwrapIfClosure() at /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:93
Illuminate\Container\BoundMethod::callBoundMethod() at /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/BoundMethod.php:35
Illuminate\Container\BoundMethod::call() at /opt/librenms/vendor/laravel/framework/src/Illuminate/Container/Container.php:662
Illuminate\Container\Container->call() at /opt/librenms/vendor/laravel/framework/src/Illuminate/Console/Command.php:211
Illuminate\Console\Command->execute() at /opt/librenms/vendor/symfony/console/Command/Command.php:326
Symfony\Component\Console\Command\Command->run() at /opt/librenms/vendor/laravel/framework/src/Illuminate/Console/Command.php:180
Illuminate\Console\Command->run() at /opt/librenms/vendor/symfony/console/Application.php:1096
Symfony\Component\Console\Application->doRunCommand() at /opt/librenms/vendor/symfony/console/Application.php:324
Symfony\Component\Console\Application->doRun() at /opt/librenms/vendor/symfony/console/Application.php:175
Symfony\Component\Console\Application->run() at /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php:201
Illuminate\Foundation\Console\Kernel->handle() at /opt/librenms/app/Console/Kernel.php:66
App\Console\Kernel->handle() at /opt/librenms/lnms:38
[PDOException (42000)]
Exception trace:
PDOStatement->execute() at /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php:580
Illuminate\Database\Connection->Illuminate\Database{closure}() at /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php:809
on cli
MariaDB [libre_db]> select column_name as name
, data_type as type_name
, column_type as type
, collation_name as collation
, is_nullable as nullable
, column_default as default
, column_comment as comment
, extra as extra
from information_schema.columns where table_schema = ‘libre_db’ and table_name = ‘bill_data’ order by ordinal_position asc ;
| name | type_name | type | collation | nullable | default | comment | extra |
| id | bigint | bigint(20) unsigned | NULL | NO | NULL | | auto_increment |
| bill_id | int | int(10) unsigned | NULL | NO | NULL | | |
| timestamp | datetime | datetime | NULL | NO | NULL | | |
| period | int | int(11) | NULL | NO | NULL | | |
| delta | bigint | bigint(20) | NULL | NO | NULL | | |
| in_delta | bigint | bigint(20) | NULL | NO | NULL | | |
| out_delta | bigint | bigint(20) | NULL | NO | NULL | | |
7 rows in set (0.004 sec)
MariaDB [libre_db]> alter table bill_data
(bill_id
, timestamp
ERROR 1061 (42000): Duplicate key name ‘bill_data_bill_id_timestamp_index’
