E-mail alerts don’t always fire when an alert is tripped, but they do always fire on recovery. Below are some screenshot examples of it firing and also not firing, but then recovery e-mails firing for alerts it failed to send when initially tripped.
I’ve also included screenshots of my alerts and e-mail configuration. I believe everything is configured correctly since alerts work correctly 80% of the time, and the problem isn’t consistent between machines, time of day, nature of problem or any other obvious trigger.
Running through audit2allow and journalctl shows no SELinux interference, and when given data to send, sendmail sends it without complaint. LibreNMS is running on RHEL7.4 with EPEL and the Webtatic repositories enabled.
[stjohnson@bambiraptor ~]$ sudo -u librenms /u01/librenms/validate.php
| LibreNMS | 1.33-245-gd6d4a3a |
| DB Schema | 224 |
| PHP | 7.0.25 |
| MySQL | 5.5.56-MariaDB |
| RRDTool | 1.4.8 |
| SNMP | NET-SNMP 5.7.2 |
Thanks in advance for your help!
