Hi @computman
Feel free to add it and submit the PullRequest in github.
If you cannot do it, you can open an issue here https://github.com/librenms/librenms/issues to fill the required data in order for somebody else to do it. Keep in mind that this list is huge and can only reduce if people from the community like you add the support.
Bye
we have a edgeswitch 8XP which is also being detected as a generic device
it has network stats but nothing else
no cpu, memory or vlans
was the pull request for the 10xp looked into?
Regards
Simon
