EdgeSwitch ports gone missing
My edge switch ports have gone missing from my devices at some point over the past few days. It looks like when I run a discovery or poller they are being discovered/ polled. It is only edge swithches, all other platforms appear to be polling and displaying normally. Validate and Daily both run without throwing errors.
Discovery: https://p.libren.ms/view/88ab3171
Poller: https://p.libren.ms/view/87066aa4
$ ./validate.php
LibreNMS 22.10.0-112-g9b41fa3f3 (2022-11-13T15:58:00-06:00)
DB Schema 2022_08_15_084507_add_rrd_type_to_wireless_sensors_table (248)
PHP 8.1.12
Python 3.8.10
Database MariaDB 10.5.9-MariaDB-1:10.5.9+maria~bionic
SNMP 5.8
[OK] Composer Version: 2.4.4
[OK]
[OK] MySQl and PHP time match
$ ./daily.sh
Updating Composer packages OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
Caching Mac OUI data OK
I finally found what my problem was.
I wanted to ignore certain types of interfaces, and in doing so made a couple of additions to the "$config[‘bad_if’][] = " list of interfaces. For some reason, and I am not going down the rabbit hole to discover the why, but adding ‘lo’ to that list made all of the ports disappear from Edge Switches.
