I have been at this all day and I can’t seem to find the issue.
I am trying to set up the syslog_hook functionality to notify oxidized that it need to spawn a worker to fetch a configuration.
I am attempting to do this for a Ubiquiti Edgeswitch.
The syslog entry created when a configuration is written is below or some variation of this, it always has the cli_txtcfg.c(840) at the start though.
cli_txtcfg.c(840) 1220 %% Text Configuration of length 5429 (222 CMDS) compressed to save 69% Flash
My config file has these entries added to this for the support per the docs. I am not a regex wizard so may have messed that part up.
$config[‘enable_syslog_hooks’] = 1;
$config[‘os’][‘edgeswitch’][‘syslog_hook’][] = Array(‘regex’ => ‘.cli_txtcfg.c(840)/’, ‘script’ => ‘/opt/librenms/scripts/syslog-notify-oxidized.php’);
I am currently tailing my nginx access log for oxidized looking for the api calls generated by the syslog-notify-oxidized.php script but am not seeing anything whenever I generate the above mentioned syslog entry.
If someone could assist with the regex or point me in the right direction it would be appreciated.
Validate Output
Component Version LibreNMS 579bfd4c3e147293ddf156ecc4d135a52de451f5 DB Schema 199 PHP 7.0.18-0ubuntu0.17.04.1 MySQL 10.1.22-MariaDB- RRDTool 1.6.0 SNMP NET-SNMP 5.7.3 ==========================================================
[WARN] Your install is out of date, last update: Sat, 15 Jul 2017 10:44:56 +0000
