Hello.
I ran into a problem trying to make a backup from the eltex2424 switches
There are no problems when working with 3324 and 2348 series switches. 2424 switches connected to the same network with similar settings do not work
At the same time, in the AAA logs, I see that oxidized successfully connects and performs a “show run”, but the data does not reach the server
oxidized_1 | D, [2023-02-01T12:02:25.875684 #29] DEBUG – : lib/oxidized/worker.rb: Added /--el2424P--** to the job queue
oxidized_1 | D, [2023-02-01T12:02:25.875695 #29] DEBUG – : lib/oxidized/worker.rb: Jobs running: 1 of 2 - ended: 1 of 2
oxidized_1 | D, [2023-02-01T12:02:25.875831 #29] DEBUG – : lib/oxidized/job.rb: Starting fetching process for --el2424P--** at 2023-02-01 12:02:25 UTC
oxidized_1 | D, [2023-02-01T12:02:25.876150 #29] DEBUG – : lib/oxidized/input/ssh.rb: Connecting to --el2424P--**
oxidized_1 | D, [2023-02-01T12:02:25.929933 #29] DEBUG – net.ssh.transport.algorithms[6b8]: exchanging keys
oxidized_1 | D, [2023-02-01T12:02:26.221557 #29] DEBUG – net.ssh.authentication.session[6e0]: beginning authentication of `’
oxidized_1 | I, [2023-02-01T12:02:26.244439 #29] INFO – net.ssh.authentication.session[6e0]:
oxidized_1 | Eltex Switch
oxidized_1 |
oxidized_1 |
oxidized_1 | D, [2023-02-01T12:02:26.244605 #29] DEBUG – socket[6cc]: received packet nr 6 type 51 len 60
oxidized_1 | D, [2023-02-01T12:02:26.362349 #29] DEBUG – net.ssh.authentication.methods.password[71c]: password succeeded
oxidized_1 | D, [2023-02-01T12:02:26.362572 #29] DEBUG – socket[6cc]: queueing packet nr 7 type 90 len 44
oxidized_1 | D, [2023-02-01T12:02:26.362703 #29] DEBUG – : lib/oxidized/input/ssh.rb: expecting [/^\s?[\[email protected]()-]+[#>]\s?$/] at --el2424P--
oxidized_1 | I, [2023-02-01T12:02:26.866554 #29] INFO – net.ssh.connection.session[730]: channel_success: 0
oxidized_1 | I, [2023-02-01T12:02:26.866688 #29] INFO – net.ssh.connection.channel[744]: sending channel request “shell”
oxidized_1 | D, [2023-02-01T12:02:26.866876 #29] DEBUG – socket[6cc]: queueing packet nr 12 type 98 len 28
oxidized_1 | D, [2023-02-01T12:02:26.876802 #29] DEBUG – : lib/oxidized/worker.rb: Jobs running: 1 of 2 - ended: 1 of 2
oxidized_1 | D, [2023-02-01T12:02:27.169427 #29] DEBUG – : lib/oxidized/input/cli.rb: Running post_login commands at --el2424P--
oxidized_1 | D, [2023-02-01T12:02:27.169695 #29] DEBUG – : lib/oxidized/input/cli.rb: Running post_login command: nil, block: #<Proc:0x00007ffb401dfea0 /root/.config/oxiW
oxidized_1 | D, [2023-02-01T12:02:27.169852 #29] DEBUG – : lib/oxidized/input/cli.rb: Running post_login command: “terminal datadump”, block: nil at --el2424P--*
oxidized_1 | D, [2023-02-01T12:02:27.169948 #29] DEBUG – : lib/oxidized/input/ssh.rb terminal datadump @ --el2424P--** with expect: /^\s?[\[email protected]()-]+[#>]\s?$/
oxidized_1 | D, [2023-02-01T12:02:27.170162 #29] DEBUG – socket[6cc]: queueing packet nr 13 type 94 len 44
oxidized_1 | D, [2023-02-01T12:02:27.170268 #29] DEBUG – : lib/oxidized/input/ssh.rb: expecting [/^\s?[\[email protected]()-]+[#>]\s?$/] at --el2424P--**
oxidized_1 | D, [2023-02-01T12:02:27.370890 #29] DEBUG – socket[6cc]: sent 68 bytes
oxidized_1 | D, [2023-02-01T12:02:27.471468 #29] DEBUG – socket[6cc]: read 2060 bytes
oxidized_1 | D, [2023-02-01T12:02:27.471897 #29] DEBUG – socket[6cc]: received packet nr 15 type 93 len 28
oxidized_1 | I, [2023-02-01T12:02:27.472066 #29] INFO – net.ssh.connection.session[730]: channel_window_adjust: 0 +1
oxidized_1 | D, [2023-02-01T12:02:27.472231 #29] DEBUG – socket[6cc]: received packet nr 16 type 94 len 28
oxidized_1 | I, [2023-02-01T12:02:27.472335 #29] INFO – net.ssh.connection.session[730]: channel_data: 0 1b
oxidized_1 | D, [2023-02-01T12:02:27.472522 #29] DEBUG – socket[6cc]: received packet nr 17 type 93 len 28
oxidized_1 | I, [2023-02-01T12:02:27.472619 #29] INFO – net.ssh.connection.session[730]: channel_window_adjust: 0 +1
oxidized_1 | D, [2023-02-01T12:02:27.578289 #29] DEBUG – : lib/oxidized/model/model.rb Collecting commands’ outputs
oxidized_1 | D, [2023-02-01T12:02:27.578356 #29] DEBUG – : lib/oxidized/model/model.rb Executing show running-config
oxidized_1 | D, [2023-02-01T12:02:27.578369 #29] DEBUG – : lib/oxidized/input/ssh.rb show running-config @ --el2424P--** with expect: /^\s?[\[email protected]()-]+[#>]\s?$/
oxidized_1 | D, [2023-02-01T12:02:27.578498 #29] DEBUG – socket[6cc]: queueing packet nr 14 type 94 len 44
oxidized_1 | D, [2023-02-01T12:02:27.578526 #29] DEBUG – : lib/oxidized/input/ssh.rb: expecting [/^\s?[\[email protected]()-]+[#>]\s?$/] at --el2424P--**
oxidized_1 | D, [2023-02-01T12:02:27.779102 #29] DEBUG – socket[6cc]: sent 68 bytes
oxidized_1 | D, [2023-02-01T12:02:27.878187 #29] DEBUG – : lib/oxidized/worker.rb: Jobs running: 1 of 2 - ended: 1 of 2
oxidized_1 | D, [2023-02-01T12:02:27.879451 #29] DEBUG – socket[6cc]: read 2080 bytes
oxidized_1 | D, [2023-02-01T12:02:27.879590 #29] DEBUG – socket[6cc]: received packet nr 54 type 93 len 28
oxidized_1 | I, [2023-02-01T12:02:27.882233 #29] INFO – net.ssh.connection.session[730]: channel_window_adjust: 0 +1
oxidized_1 | D, [2023-02-01T12:02:27.882270 #29] DEBUG – socket[6cc]: received packet nr 93 type 94 len 28
oxidized_1 | I, [2023-02-01T12:02:27.882291 #29] INFO – net.ssh.connection.session[730]: channel_data: 0 1b
oxidized_1 | D, [2023-02-01T12:02:27.882386 #29] DEBUG – socket[6cc]: read 52 bytes
oxidized_1 | D, [2023-02-01T12:02:27.882447 #29] DEBUG – socket[6cc]: received packet nr 94 type 94 len 28
oxidized_1 | I, [2023-02-01T12:02:27.882473 #29] INFO – net.ssh.connection.session[730]: channel_data: 0 2b
oxidized_1 | I, [2023-02-01T12:02:28.082959 #29] INFO – net.ssh.connection.keepalive[758]: sending keepalive 0
oxidized_1 | I, [2023-02-01T12:02:28.083020 #29] INFO – net.ssh.connection.session[730]: sending global request [email protected]
oxidized_1 | I, [2023-02-01T12:02:28.588784 #29] INFO – net.ssh.connection.session[730]: channel_data: 0 16b
oxidized_1 | D, [2023-02-01T12:02:28.588846 #29] DEBUG – socket[6cc]: received packet nr 119 type 82 len 12
oxidized_1 | I, [2023-02-01T12:02:28.588866 #29] INFO – net.ssh.connection.session[730]: global request failure
oxidized_1 | D, [2023-02-01T12:02:28.588918 #29] DEBUG – net.ssh.connection.keepalive[758]: keepalive response successful. Missed 0 keepalives
oxidized_1 | D, [2023-02-01T12:02:28.879656 #29] DEBUG – : lib/oxidized/worker.rb: Jobs running: 1 of 2 - ended: 1 of 2
