Hello masters, I’m configuring an email alert on libreNMS using postfix. I do successfully installed postfix and configured it sending email manually using mail command using the relay of [smtp.gmail.com]:587. I’m having a hard time to configure librenms to send an alerts via email. Can someone guide mo on this to make things worked?
Things that I have done so far:
configure the global settings under alerting tab, email options
The rule should not be “set to use postfix”. The rule is the condition to trigger the alert. So condition is “device down and status=ICMP”. Remove the 3rd condition, and you’ll see the alert in the LibreNMS GUI.
Then you’ll have to create an Email Alert Transport, and map it to your alert.
