Email notification not show any detail
Hi All,
I’ve got the problem the email notification not show any detail as attached picture.
Do you have the problem like this please advice.
You have errors in your alert template. Double check the templates for errors.
Kevin,
Thanks for your advice , It work now after change the template to the new format.
