Hello
I would like to get notification via email from librenms when power ac will be down and when will comeback.
I connected olt x7 5800 with SMU01C wia ethernet. I can read data from SMU01C.
olt(config-if-smu-1)#display power run info
EMU ID: 1 System run information
Limit State : No limit Charge control : Automatic control
Charge state : Floating
Module number : 2
Module 0 address : 1 Module 0 type : AC/DC
Module 1 address : 2 Module 1 type : AC/DC
Module 0 voltage : 53.66V Module 0 current : 1.87A
Module 1 voltage : 53.68V Module 1 current : 1.94A
DC voltage : 53.61V AC voltage : 240.90V
Load current : 3.79 A Battery current : 0.00 A
Battery capacity remained: 100 %
Librenms also sends info.
2023-03-03 09:45:44 | State sensor AC Power State has changed from offline (2) to normal (1) | |
2023-03-03 09:40:44 | State sensor AC Power State has changed from normal (1) to offline (2) | |
2023-03-03 09:40:44 | Voltage under threshold: 0 V (< 205.53 V) | |
2023-03-02 21:57:00 | Location: xxxx |
