Hi, I’m a new convert to LibreNMS from Observium, and I love it! Can someone get me started with embedding LibreNMS graphs on a simple webpage that I want to create as a help desk portal homepage? I know basic html and some scripting, but I’m not a pro at coding. Thanks so much!
You can use the API.
Thanks for pointing me to the correct API!
Sorry to bug you again, but could you point me to some API code examples to get me started? I’m a total newbie when it comes to this kind of code.
I’d like to build a web page “console” that has a dozen key graphs embedded in it so I can have instant feedback about some key network devices.
Thanks for your patience!
