Enable billing
Hi all!
I’m using LibreNMS in Docker.
In the config it seems that the module is enabled:
bash-5.1# cat config.php | grep billing
# Enable the in-built billing extension
$config['enable_billing'] = 1;
Poller settings:
However in Global settings it seems disabled.
And I can’t find it anywhere on the web interface, where I could setup billing/quotas.
Thanks for your help in advance!
under ports->Traffic bills
Thanks, I have found it!
