So I started a new job recently (as the only person in the tech department) and found that my predecessors haven’t allowed an update to LibreNMS since sometime before March 2020. There were a ton of error messages in the notifications and the terminal was showing MariaDB 5.5 and Python 2.7.
I went through the update process according to other documentation on these help articles (thank you so much everyone) - python now shows 3.6 and MariaDB was up to 10.5. However, during the upgrade the ./env file someone disappeared and searching in the rrd directory, I do not see another file with that name that I can copy to recreate it (I saw that was a recommendation from another user unless I’m not understanding that correctly). The ./validate.php command is showing DB Schema is showing “Not Connected” with the updated python version, but I can’t get much more out of it than that.
In an apparently feeble attempt to figure this out, I followed documentation from NGINX and LibreNMS to start from scratch on my home servers. I followed every single step twice (two separate VMs) - just copying commands that were provided - but even still there is not ./env file and I can’t get the DB Schema connected to something so I can get this up and running again.
Is there a way to create the ./env file from the config.php file or anything I should do to possibly correct this?
At my job site the VM is CentOS 7 and at my home the VMs are CentOS 8.
(I hate to ask this, but if possible, please understand I’m new to Libre and only dabbled a bit in the Linux world)
Output from validate.php on one of my home VMs with a fresh install of LibreNMS (I’m not seeing a spot to mark the following as a block of code):
[l[email protected] ~]$ ./validate.php
Component | Version |
LibreNMS | 21.12.1-38-g2d24b2cf9 |
DB Schema | Not Connected (0) |
PHP | 7.3.20 |
Python | 3.6.8 |
MySQL | ? |
RRDTool | 1.7.0 |
SNMP | 5.8 |
[OK] Composer Version: 2.2.5
[[email protected] ~]$
