I have followed the instructions here: https://docs.librenms.org/Installation/Installation-Ubuntu-1804-Nginx/
I currently get “ERR_CONNECTION_REFUSED” when I try to access the webui. I can access the webui just fine with the IP address.
| LibreNMS | 1.53.1-17-g394d66a3f |
| DB Schema | 2019_05_30_225937_device_groups_rewrite (135) |
| PHP | 7.2.19-0ubuntu0.18.04.1 |
| MySQL | 10.1.40-MariaDB-0ubuntu0.18.04.1 |
| RRDTool | 1.7.0 |
| SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.8.6
server {
listen 80;
server_name librenms.ad.mydomain.co.uk;
root /opt/librenms/html;
index index.php;
charset utf-8;
gzip on;
location / {
location /api/v0 {
try_files $uri $uri/ /api_v0.php?$query_string;
location ~ .php {
include fastcgi.conf;
fastcgi_split_path_info ^(.+.php)(/.+)$;
fastcgi_pass unix:/var/run/php/php7.2-fpm.sock;
location ~ /.ht {
deny all;
