this morning, i have an error on PYthon3
ubuntu 18.04
Component |
Version |
LibreNMS |
1.63-41-g25330646f |
DB Schema |
2020_04_19_010532_eventlog_sensor_reference_cleanup (164) |
PHP |
7.2.24-0ubuntu0.18.04.4 |
Python |
3.6.9 |
MySQL |
10.1.44-MariaDB-0ubuntu0.18.04.1 |
RRDTool |
1.7.0 |
SNMP |
NET-SNMP 5.7.3 |
[OK] Composer Version: 1.10.6
[FAIL] Python3 module issue found: âThe âredis>=3.0â distribution was not found and is required by the applicationâ
Can you help me ?
Run pip3 install -r requirements.txt
Itâs perfect thanks a lot
Many thanks.
I had the same issue exactly.
The solution works fine.
Hi, worked also for me while using the ./validate.php script. However, when I check in the librenms GUI, it still says the error is there: Fail: Python3 module issue found: âThe âredis>=3.0â distribution was not found and is required by the applicationâ
Any hints why the script results different than the GUI in librenms?
Regards
Stefan
I am getting this same error after a fresh install on Ubuntu 18.04 and following the documentation for NGINX install. When running the librenms installation step, I did notice an error about pip3 not being found. I do not see pip3 in the /opt/librenms directory. Is pip3 found somewhere else?
Thanks! That works. That package is missing from the list of packages to install in the documentation for Ubuntu 18.04 and NGINX.
After fixing pip3 with apt and doing âpip3 install -r requirements.txtâ and restarting apache, the error also remains visisble in the validate.php webpage, NOT the CLI validate.php output.
I am getting the same error on a brand new install of Ubuntu 18.04 and LibreNMS. Iâve run pip3 against the requirements.txt, it installs and the error persists:
#:/opt/librenms# su librenms
$ pip3 install -r requirements.txt
Collecting PyMySQL (from -r requirements.txt (line 1))
Using cached https://files.pythonhosted.org/packages/ed/39/15045ae46f2a123019aa968dfcba0396c161c20f855f11dea6796bcaae95/PyMySQL-0.9.3-py2.py3-none-any.whl
Collecting python-dotenv (from -r requirements.txt (line 2))
Using cached https://files.pythonhosted.org/packages/cb/2a/07f87440444fdf2c5870a710b6770d766a1c7df9c827b0c90e807f1fb4c5/python_dotenv-0.13.0-py2.py3-none-any.whl
Collecting redis>=3.0 (from -r requirements.txt (line 3))
Using cached https://files.pythonhosted.org/packages/d2/07/20cb8df2ded4b5db176a65da48b7c8d4295d868776296580b11071218a2b/redis-3.5.0-py2.py3-none-any.whl
Installing collected packages: PyMySQL, python-dotenv, redis
Successfully installed PyMySQL-0.9.3 python-dotenv-0.13.0 redis-3.5.0
# ./validate.php
LibreNMS | 1.63-41-g25330646f
DB Schema | 2020_04_19_010532_eventlog_sensor_reference_cleanup (164)
PHP | 7.2.24-0ubuntu0.18.04.4
Python | 3.6.9
MySQL | 10.1.44-MariaDB-0ubuntu0.18.04.1
RRDTool | 1.7.0
SNMP | NET-SNMP 5.7.3
[FAIL] Python3 module issue found: 'The 'redis>=3.0' distribution was not found and is required by the application'
Modified Files:
bootstrap/cache/.gitignore
logs/.gitignore
rrd/.gitignore
storage/app/.gitignore
storage/app/public/.gitignore
storage/debugbar/.gitignore
storage/logs/.gitignore
I have the same problem, the webinterface complains about missing redis>=3.0 but validate.php shows no error. I restarted both nginx and php7.3-fpm (debian buster).
Also, pip3 install -r requirements.txt confirms it is already installed:
Requirement already satisfied: PyMySQL in ./.local/lib/python3.7/site-packages (from -r requirements.txt (line 1)) (0.9.3)
Requirement already satisfied: python-dotenv in ./.local/lib/python3.7/site-packages (from -r requirements.txt (line 2)) (0.13.0)
Requirement already satisfied: redis>=3.0 in ./.local/lib/python3.7/site-packages (from -r requirements.txt (line 3)) (3.5.0)
If you install the requirements as root, you wonât get a web error.
However, I have a PR to disable the web check when the web server isnât running as the poller user. As it could be inaccurate then (as you all have seen).
You have to use: sudo -H pip3 install -r requirements.txt
And all will be well in the Web page also.
If you simply do a sudo pip3 install -r requirements.txt it says so.
but it also says that âRequirement already satisfied: âŚâ
And even more confusing if you donât use âsudoâ as a non prived user , it says:
âSuccessfully installed PyMySQL-0.9.3 python-dotenv-0.13.0 redis-3.5.0â
So try: âsudo -Hâ as suggested when running sudo without options.
my 2 cents.
Thatâs the fix, many thanks.
This worked for me. Thank you.
