Erroneous ports
Hi All
Is there a way to stop LibreNMS detecting erroneous ports on Windows servers?
There is only 1 NIC on each server, but all have loads of ports reported/discovered in LibreNMS.
I know I can disable by port, but I have over 200 servers and am looking for a easier way to do it.
Example of the reported/discovered ports from 1 server:
Sorry forgot to add system info
CentOS 7
Libre NMS Version 22.8.0
can be disabled in config.php
$config[‘bad_iftype’][] = “Tunnel_6to4”;
$config[‘bad_if’][] = “mgmt0”;
you can also use regex to match to your interface name/description
Hi
Many thanks, will give it a go.
