Having issues resolving this table error. I recently switched to the stable release and now have these errors. There were about 20-30 others but I was able to resolve them by pasting the fix into the SQL server.
ALTER TABLE ‘pollers’ DROP INDEX PRIMARY
PRIMARY KEY (poller_name
ERROR 1064 (42000): You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ‘‘pollers’ DROP INDEX PRIMARY
)’ at line 1
Component | Version |
LibreNMS | 1.43 |
DB Schema | 268 |
PHP | 7.2.10-0ubuntu0.18.04.1 |
MySQL | 10.1.34-MariaDB-0ubuntu0.18.04.1 |
RRDTool | 1.7.0 |
SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.7.2
[WARN] Your schema (268) is newer than than expected (262). If you just switch to the stable release from the daily release, your database is in between releases and this will be resolved with the next release.
[FAIL] Database: incorrect index (pollers/PRIMARY)
[FAIL] Database: incorrect index (poller_cluster/PRIMARY)
[FAIL] Database: incorrect index (poller_cluster_stats/PRIMARY)
SQL Statements:
ALTER TABLE pollers
DROP INDEX PRIMARY
, PRIMARY KEY (poller_name
ALTER TABLE poller_cluster
DROP INDEX PRIMARY
, PRIMARY KEY (node_id
ALTER TABLE poller_cluster_stats
DROP INDEX PRIMARY
, PRIMARY KEY (parent_poller
,poller_type
[FIX] Check your poll log and see:
Devices:
10.3.1.125
[FAIL] Some devices have not completed their polling run in 5 minutes, this will create gaps in data.
Devices:
10.3.1.125
[FIX] Check the cron job to make sure it is running and using discovery-wrapper.py
