Yesterday librenms was working fine, this morning I arrived at work and it gives me an error in the bd and does not connect … I attached capture, any ideas? Thanks in advance, regards.
it says to look your log file.
and what that tels you?
i think its your database
Would it have something to do that changed the password for the librenms user? I understand that no … since the bd uses another user
I am connected via putty and I don’t know how to share the log file, can you tell me how to do it?
if u changed the librenms user
go to :
/opt/librenms/config.php
look for :
Database config
$config[‘db_host’] = ‘localhost’;
$config[‘db_port’] = ‘3306’;
$config[‘db_user’] = ‘librenms’;
$config[‘db_pass’] = ‘yourpass’;
$config[‘db_name’] = ‘librenms’;
$config[‘db_socket’] = ‘’;
Does this has the correct user/pass?
Also check your .env file
try change from localhost to 127.0.0.1 in both config.php and .env file also, apparently this can fix such an error
Good morning, I do not know what it would be, but between I put the password again and restart and little else and it worked … I do not know … I do not see logic, it is more copy and paste the same key that I had in the config file
At least its solved
have fun monitoring
Thanks xDD ![]()
