I am following the instructions of jarischaefer to run librenms in a container. The problem is that it always tells me that it can not connect to the database.
root@librenms:/# /opt/librenms/./validate.php
| LibreNMS | 1.44 |
| DB Schema | ? |
| PHP | 7.2.11-2+ubuntu18.04.1+deb.sury.org+1 |
| MySQL | ? |
| RRDTool | 1.7.0 |
| SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.7.3
[FAIL] Error connecting to your database.
[WARN] Could not check poller/discovery, db is not connected.
[WARN] Your install is over 24 hours out of date, last update: Wed, 17 Oct 2018 10:33:28 +0000
[FIX] You can switch back to master with git checkout master
This is my docker run parameters:
docker run -d -h librenms -p 80:80 -e APP_KEY=(key genereate with generate key) -e DB_HOST=127.0.0.1 -e DB_NAME=librenms -e DB_USER=librenms -e DB_PASS=(password equan than mysql) -e BASE_URL=http://localhost -v /data/logs:/opt/librenms/logs -v /data/rrd:/opt/librenms/rrd --name librenms jarischaefer/docker-librenms
After this i try to create tables but database is not connected
I think all mysql parameters are well… pse help…
Thanks in advance
