Howdy.
Here’s an environment breakdown.
Updating Composer packages OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
When running validate.php, the following output is seen:
LibreNMS | 1.43-127-g54de884
DB Schema | 268
PHP | 7.0.32-0ubuntu0.16.04.1
MySQL | 10.0.36-MariaDB-0ubuntu0.16.04.1
RRDTool | 1.5.5
SNMP | NET-SNMP 5.7.3
[OK] Composer Version: 1.7.2
From looking at older posts, I will stress that my RRDTool version is 1.5.5, not 1.6.x or 1.4.x.
The Problem
My specific issue is related to a processor usage of a single device (as far as I can tell).
Attached is a screenshot of an example of what I’m seeing. The processor usage graph is all red and when selected I’m given the “Error Drawing Graph”.
I read from another thread that I can append the image link’s address with ‘&debug=true’ to get an error of a sorts. That is attached here.
SQL[SELECT `devices`.*, `lat`, `lng` FROM `devices` LEFT JOIN locations ON `devices`.`location`=`locations`.`location` WHERE `device_id` = ? ["18"] 0.35ms] SQL[SELECT * FROM devices_attribs WHERE `device_id` = ? [18] 0.17ms] SQL[SELECT * FROM `vrf_lite_cisco` WHERE `device_id` = ? ["18"] 0.17ms] SQL[SELECT attrib_value FROM devices_attribs WHERE `device_id` = ? AND `attrib_type` = ? [18,"poll_mib"] 0.17ms] SQL[SELECT * FROM `processors` where `device_id` = ? [18] 0.16ms]
Warning: substr_count(): Length value 14 exceeds string length in /opt/librenms/includes/rrdtool.inc.php on line 284
Warning: Invalid argument supplied for foreach() in /opt/librenms/html/includes/graphs/generic_multi_simplex_seperated.inc.php on line 23
graph /tmp/aMJGPcBmKkpgTykS -l 0 -u 100 -E --start 1538428800 --end 1538515200 --width 1512 --height 313 -c BACK#EEEEEE00 -c SHADEA#EEEEEE00 -c SHADEB#EEEEEE00 -c FONT#000000 -c CANVAS#FFFFFF00 -c GRID#a5a5a5 -c MGRID#FF9999 -c FRAME#5e5e5e -c ARROW#5e5e5e -R normal --font LEGEND:8:DejaVuSansMono --font AXIS:7:DejaVuSansMono --font-render-mode normal COMMENT:'Load % Now Min Max Avg\l'
command returned (OK u:0.00 s:0.00 r:0.00 )
graph /tmp/aMJGPcBmKkpgTykS --alt-autoscale-max --rigid -E --start 1538428800 --end 1538515200 --width 1512 --height 313 -c BACK#EEEEEE00 -c SHADEA#EEEEEE00 -c SHADEB#EEEEEE00 -c FONT#000000 -c CANVAS#FFFFFF00 -c GRID#a5a5a5 -c MGRID#FF9999 -c FRAME#5e5e5e -c ARROW#5e5e5e -R normal --font LEGEND:8:DejaVuSansMono --font AXIS:7:DejaVuSansMono --font-render-mode normal HRULE:0#555555 --title='Error Drawing Graph'
command returned (1593x372 OK u:0.06 s:0.00 r:0.06 )
Runtime 0.087s
MySQL [5/0.00s]: Cell[0/0.00s] Row[2/0.00s] Rows[-1/-0.00s] Column[4/0.00s] Update[0/0.00s] Insert[0/0.00s] Delete[0/0.00s]
When did this problem start
I was trying to setup SMART (HDD) monitoring on a server I was monitoring and I ran into a NaN graph problem. Part of my troubleshooting method was to check ./validate.php and I returned/executed the following permission-related commands.
[FIX] sudo chown -R librenms:librenms /opt/librenms
Since then, this has been a problem.
Can anyone please shed some light on this?
