After the installation some maps were working but now none of the maps are working. I checked other posts but wasn’t helpful. Please assist.
[root@nms librenms]# ./validate.php
| Component |
Version |
| LibreNMS |
1.31.03-45-gb4d804f |
| DB Schema |
206 |
| PHP |
7.0.21 |
| MySQL |
5.5.52-MariaDB |
| RRDTool |
1.4.8 |
| SNMP |
NET-SNMP 5.7.2 |
dimaar,
I’m confused…
Can you post a screen shot of what you are talking about… you title says graph but then you say you maps are working but now you don’t see maps??
So are network maps not working for you
and
Are graphs not loading?
Kevin,
Thanks for the quick response. That was a typo.I meant the graphs not maps. I guess I should have been little more patient. I tried deleting all existing folders in rrd directory and it appears to be working now. Thanks again
No worries
happy monitoring!
Just adding a comment so it might be helpful to others. Deleting folders in rrd directory didn’t help. Checking the debug of the graph link, I saw “Pango-WARNING **: error opening config file ‘/root/.config/pango/pangorc’: Permission denied )”.Disabled selinux and that did the trick.
