I’m not running memcache.
I did upgrade to RRDTool 1.6.0, and things are getting a little better.
Here’s the validate results.
[root@itlibrenms ~]# /opt/librenms/validate.php
LibreNMS | 1.30-44-g3ca6f84
DB Schema | 201
PHP | 7.0.21
MySQL | 5.5.52-MariaDB
RRDTool | 1.6.0
SNMP | NET-SNMP 5.7.2
Here’s the new results from the RRD command:
RRDTool Command
rrdtool graph /tmp/v7jZySu1Ii5zT5g7 -g --alt-autoscale-max --rigid -E --start 1502206500 --end 1502292900 --width 1219.5 --height 300 -c BACK#EEEEEE00 -c SHADEA#EEEEEE00 -c SHADEB#EEEEEE00 -c FONT#000000 -c CANVAS#FFFFFF00 -c GRID#a5a5a5 -c MGRID#FF9999 -c FRAME#5e5e5e -c ARROW#5e5e5e -R normal --font LEGEND:8:DejaVuSansMono --font AXIS:7:DejaVuSansMono --font-render-mode normal COMMENT:' Now Avg Max' COMMENT:'\n' CDEF:inB= CDEF:outB= CDEF:octets=inB,outB,+ CDEF:doutB=outB,-1,* CDEF:inbits=inB,8,* CDEF:outbits=outB,8,* CDEF:bits=inbits,outbits,+ CDEF:doutbits=doutB,8,* VDEF:95thin=inbits,95,PERCENT VDEF:95thout=outbits,95,PERCENT CDEF:d95thoutn=doutbits,-1,* VDEF:d95thoutn95=d95thoutn,95,PERCENT CDEF:d95thoutn95n=doutbits,doutbits,-,d95thoutn95,-1,*,+ VDEF:d95thout=d95thoutn95n,FIRST VDEF:totin=inB,TOTAL VDEF:avein=inbits,AVERAGE VDEF:totout=outB,TOTAL VDEF:aveout=outbits,AVERAGE VDEF:tot=octets,TOTAL COMMENT:' \n' HRULE:999999999999999#FFFFFF:'Total In ' GPRINT:inbits:LAST:%6.2lf%s GPRINT:inbits:AVERAGE:%6.2lf%s GPRINT:inbits:MAX:%6.2lf%s GPRINT:totin:%6.2lf%sB COMMENT:'\n' HRULE:999999999999990#FFFFFF:' Out' GPRINT:outbits:LAST:%6.2lf%s GPRINT:outbits:AVERAGE:%6.2lf%s GPRINT:outbits:MAX:%6.2lf%s GPRINT:totout:%6.2lf%sB COMMENT:'\n' HRULE:999999999999990#FFFFFF:' Agg' GPRINT:bits:LAST:%6.2lf%s GPRINT:bits:AVERAGE:%6.2lf%s GPRINT:bits:MAX:%6.2lf%s GPRINT:tot:%6.2lf%sB COMMENT:'\n' HRULE:0#999999
RRDTool Output
ERROR: can not parse an empty rpn expression
