Hellow everyone !!
I am not able to add fortigate device in librenms.I have created snmp and enabled in fortigate interface too.In librenms i am able to add other device with similar config. However i am able to add fortigate without snmp.I tried both from GUI and terminal to add fortigate with snmp but is not working.I will love to hear suggestion and link
Did you allowed your librenms IP in the fortigate’s snmp conf?
yes i did…
I am able to add other device with similar config
Try snmpwalk -v2c -cYOURCOMMUNITY fortigateip . from librenms server
(Thats guessing you are using snmp v2)
If no response, that means your fortigate is not replying to snmp
Thank you for suggestion.i will try with it
My syntax
is providing list of of option…Can you help me with correct syntax.In fortigate i have enabled both snmp(v1 and v2c)
Try this one:
snmpget -v2c -cCOMMUNITY -m ALL -M /opt/librenms/mibs fortigateip sysObjectID.0
I got this one as output:SNMPv2-MIB::sysObjectID.0 = OID: SNMPv2-SMI::enterprises.12356.101.1.2009
what could this mean
What error do you get when adding to LibreNMS?
Thank you bro.It worked.
