I’m having trouble discovering and polling one of our core devices. It seems like the device is not being monitored correctly as all the ports are missing that make up the rrdtool graph.
This is the error that rrdtool graph command gives:
ERROR: String ends after the = sign on ‘CDEF:inB=’
https://p.libren.ms/view/3bf6b65f
https://p.libren.ms/view/878a30ff
Issuing the discovery script I eventually come accross this error:
“Error in fdb-table module. SQLSTATE[23000]: Integrity constraint violation: 1048 Column ‘port_id’ cannot be null (SQL: insert into ports_fdb
(port_id
, mac_address
, vlan_id
, device_id
, created_at
, updated_at
) values (?, 00005e00010a, 0, 554, 2020-01-17 14:57:45, 2020-01-17 14:57:45))”
Not sure how to fix this
Beelze
