Tried to give composer access to online repo via a github token
(which is not stricly necessary) and saw:
php /opt/librenms/composer.phar outdated
GitHub API limit (60 calls/hr) is exhausted, could not fetch https://api.github.com/repos/librenms/StringBladeCompiler/contents/composer.json?ref=. Create a GitHub OAuth token to go over the API rate limit. You can also wait until 2020-02-04 21:21:02 for the rate limit to reset.
Head to https://github.com/settings/tokens/new?scopes=repo&description=Composer+on+librenms+<some_numbers>
to retrieve a token. It will be stored in “/home/librenms/.composer/auth.json” for future use by Composer.
Token (hidden):
Token stored successfully.
amenadiel/jpgraph 3.6.21 4.0.3 jpGraph, library to make graphs and charts
darkghosthunter/larapoke v3.1.0 v4.0.0 Keep your forms alive, avoid TokenMismatchException by gently po…
dnoegel/php-xdg-base-dir 0.1 v0.1.1 implementation of xdg base directory specification for php
doctrine/cache 1.9.1 1.10.0 PHP Doctrine Cache library is a popular cache implementation tha…
doctrine/dbal v2.9.3 v2.10.1 Powerful PHP database abstraction layer (DBAL) with many feature…
doctrine/lexer 1.0.2 1.2.0 PHP Doctrine Lexer parser library that can be used in Top-Down, …
egulias/email-validator 2.1.11 2.1.15 A library for validating emails against several RFCs
erusev/parsedown 1.7.3 1.7.4 Parser for Markdown.
fideloper/proxy 4.2.1 4.2.2 Set trusted proxies for Laravel
guzzlehttp/guzzle 6.4.1 6.5.2 Guzzle is a PHP HTTP client library
laravel/framework v5.8.35 v6.14.0 The Laravel Framework.
laravel/laravel v5.8.35 v6.12.0 The Laravel Framework.
laravel/tinker v1.0.10 v2.1.0 Powerful REPL for the Laravel framework.
league/flysystem 1.0.57 1.0.63 Filesystem abstraction: Many filesystems, one API.
monolog/monolog 1.25.2 2.0.2 Sends your logs to files, sockets, inboxes, databases and variou…
nesbot/carbon 2.27.0 2.29.1 An API extension for DateTime that supports 281 different langua…
opis/closure 3.4.1 3.5.1 A library that can be used to serialize closures (anonymous func…
php-amqplib/php-amqplib v2.0.2 v2.11.0 This library is a pure PHP implementation of the AMQP protocol. …
phpmailer/phpmailer v6.1.3 v6.1.4 PHPMailer is a full-featured email creation and transfer class f…
phpoption/phpoption 1.5.2 1.7.2 Option Type for PHP
psy/psysh v0.9.9 v0.9.12 An interactive shell for modern PHP.
ramsey/uuid 3.8.0 3.9.2 Formerly rhumsaa/uuid. A PHP 5.4+ library for generating RFC 412…
spatie/laravel-cors 1.3.3 1.6.0 Send CORS headers in a Laravel or Lumen application
symfony/console v4.4.0 v5.0.4 Symfony Console Component
symfony/css-selector v4.4.0 v5.0.4 Symfony CssSelector Component
symfony/debug v4.4.0 v4.4.4 Symfony Debug Component
symfony/dotenv v3.4.35 v5.0.4 Registers environment variables from a .env file
symfony/error-handler v4.4.0 v5.0.4 Symfony ErrorHandler Component
symfony/event-dispatcher v4.4.0 v5.0.4 Symfony EventDispatcher Component
symfony/event-dispatcher-contracts v1.1.7 v2.0.1 Generic abstractions related to dispatching event
symfony/finder v4.4.0 v5.0.4 Symfony Finder Component
symfony/http-foundation v4.4.0 v5.0.4 Symfony HttpFoundation Component
symfony/http-kernel v4.4.0 v5.0.4 Symfony HttpKernel Component
symfony/mime v4.4.0 v5.0.4 A library to manipulate MIME messages
symfony/polyfill-ctype v1.12.0 v1.13.1 Symfony polyfill for ctype functions
symfony/polyfill-iconv v1.12.0 v1.13.1 Symfony polyfill for the Iconv extension
symfony/polyfill-intl-idn v1.12.0 v1.13.1 Symfony polyfill for intl’s idn_to_ascii and idn_to_utf8 functions
symfony/polyfill-mbstring v1.12.0 v1.13.1 Symfony polyfill for the Mbstring extension
symfony/polyfill-php72 v1.12.0 v1.13.1 Symfony polyfill backporting some PHP 7.2+ features to lower PHP…
symfony/polyfill-php73 v1.12.0 v1.13.1 Symfony polyfill backporting some PHP 7.3+ features to lower PHP…
symfony/process v4.4.0 v5.0.4 Symfony Process Component
symfony/routing v4.4.0 v5.0.4 Symfony Routing Component
symfony/service-contracts v1.1.8 v2.0.1 Generic abstractions related to writing services
symfony/translation v4.4.0 v5.0.4 Symfony Translation Component
symfony/translation-contracts v1.1.7 v2.0.1 Generic abstractions related to translation
symfony/var-dumper v4.4.0 v5.0.4 Symfony mechanism for exploring and dumping PHP variables
symfony/yaml v4.4.0 v5.0.4 Symfony Yaml Component
tecnickcom/tcpdf 6.2.26 6.3.2 TCPDF is a PHP class for generating PDF documents and barcodes.
tightenco/ziggy v0.7.1 v0.8.1 Generates a Blade directive exporting all of your named Laravel …
vlucas/phpdotenv v3.6.0 v4.1.0 Loads environment variables from .env
to getenv()
, $_ENV
a…
wpb/string-blade-compiler 3.8.x-dev b3e340b dev-master 1263244 Laravel Blade String Compiler, render string as blade templates
But a ./scripts/composer_wrapper.php install --no-dev
Nothing to install or update
Illuminate\Foundation\ComposerScripts::postAutoloadDump
@php artisan package:discover --ansi
Discovered Package: darkghosthunter/larapoke
Discovered Package: fideloper/proxy
Discovered Package: laravel/laravel
Discovered Package: laravel/tinker
Discovered Package: martinlindhe/laravel-vue-i18n-generator
Discovered Package: nesbot/carbon
Discovered Package: oriceon/toastr-5-laravel
Discovered Package: spatie/laravel-cors
Discovered Package: tightenco/ziggy
Package manifest generated successfully.
LibreNMS\ComposerHelper::postInstall
Illuminate\Foundation\ComposerScripts::postInstall
@php artisan vue-i18n:generate --multi-locales --format=umd
Doesn’t seem to update anything. Any other ideas ?
TIA
