Error: Missing dependencies! - Librenms
Hello guys,
I’ve just got this message when I try to access my Librenms:
Error: Missing dependencies! Run the following command to fix:
Do I need just to run this command to fix this problem? or need something else.
Tks
Indeed you do
Tks laf for the prompt answer.,
is there a specific folder to run this command like: /opt/librenms/scripts ? or just run whatever locations I want?
From /opt/librenms as librenms user.
Hi Lard,
I tried to run the following command and the system didn’t recoganize the argument --no-dev as shows bellow::
[[email protected] librenms]# runuser -l librenms -c ./scripts/composer_wrapper.php install --no-dev
runuser: unrecognized option ‘–no-dev’
Do you know if is this line is correct ?
Tks for your reply.
I Just saw the post here from manyhats081d, I’ll try his procedure:
manyhats081d
I tried the:
./opt/librenms/scripts/composer_wrapper.php install --no-dev
it failed. So I did the yum update since it was my chance to catch up, rebooted, ran the command again. I got the ext-mbstring error listed by others above. I did yum install php70w-mbstring and rebooted. Now it works.
Thanks to everyone above for the help. much love for you all
iI fllowed this procedure and now the mbstring is ok, however I got another problem qhen I try to access the webui:
Error: bootstrap/cache, storage, storage/framework/sessions, storage/framework/views, storage/framework/cache not writable! Run these commands as root on your LibreNMS server to fix:
chown -R librenms:librenms /opt/librenms/bootstrap/cache /opt/librenms/storage /opt/librenms/storage/framework/sessions /opt/librenms/storage/framework/views /opt/librenms/storage/framework/cache
setfacl -R -m g::rwx /opt/librenms/bootstrap/cache /opt/librenms/storage /opt/librenms/storage/framework/sessions /opt/librenms/storage/framework/views /opt/librenms/storage/framework/cache
setfacl -d -m g::rwx /opt/librenms/bootstrap/cache /opt/librenms/storage /opt/librenms/storage/framework/sessions /opt/librenms/storage/framework/views /opt/librenms/storage/framework/cache
I Run these command and I still get the error, any ideas?
look what I did:
[[email protected] librenms]# chown -R librenms:librenms /opt/librenms/bootstrap/cache
[[email protected] librenms]# chown -R librenms:librenms /opt/librenms/storage
[[email protected] librenms]# chown -R librenms:librenms /opt/librenms/storage/framework/sessions
[[email protected] librenms]# chown -R librenms:librenms /opt/librenms/storage/framework/views
[[email protected] librenms]# chown -R librenms:librenms /opt/librenms/storage/framework/cache
[[email protected] librenms]# setfacl -R -m g::rwx /opt/librenms/bootstrap/cache
[[email protected] librenms]# setfacl -R -m g::rwx /opt/librenms/storage
[[email protected] librenms]# setfacl -R -m g::rwx /opt/librenms/storage/framework/sessions
[[email protected] librenms]# setfacl -R -m g::rwx /opt/librenms/storage/framework/views
[[email protected] librenms]# setfacl -R -m g::rwx /opt/librenms/storage/framework/cache
[[email protected] librenms]# setfacl -d -m g::rwx /opt/librenms/bootstrap/cache
[[email protected] librenms]# setfacl -d -m g::rwx /opt/librenms/storage
[[email protected] librenms]# setfacl -d -m g::rwx /opt/librenms/storage/framework/sessions
[[email protected] librenms]# setfacl -d -m g::rwx /opt/librenms/storage/framework/views
[[email protected] librenms]# setfacl -d -m g::rwx /opt/librenms/storage/framework/cache
I might recommend you run “validate.php” to double check.
I did already:
[[email protected] librenms]# ./validate.php
LibreNMS 1.39-41-g824ce31
DB Schema 249
PHP 7.0.29
MySQL 5.5.56-MariaDB
RRDTool 1.4.8
SNMP NET-SNMP 5.7.2
[OK] Composer Version: 1.6.5
but still getting the message.
I always su librenms before running validate - you might try that.
its really strange, I just ran that now and nothin happen:
[[email protected] ~]# su librenms
bash-4.2$ cd /opt/librenms/
bash-4.2$ ./validate.php
DB Schema 249
PHP 7.0.29
RRDTool 1.4.8
SNMP NET-SNMP 5.7.2
Any other idea?
Restart the web server/php-fpm?
How can I do that? systemctl restart php-fpm?
I rebooted the server also.
Tks Laf
What actual error are you getting?
Sorry for the delay, I was out of office today, here it is:
If using SELinux you may also need:
semanage fcontext -a -t httpd_sys_content_t ‘/opt/librenms/bootstrap/cache(/.*)?’
semanage fcontext -a -t httpd_sys_rw_content_t ‘/opt/librenms/bootstrap/cache(/.*)?’
restorecon -RFvv /opt/librenms/bootstrap/cache
semanage fcontext -a -t httpd_sys_content_t ‘/opt/librenms/storage(/.*)?’
semanage fcontext -a -t httpd_sys_rw_content_t ‘/opt/librenms/storage(/.*)?’
restorecon -RFvv /opt/librenms/storage
semanage fcontext -a -t httpd_sys_content_t ‘/opt/librenms/storage/framework/sessions(/.*)?’
semanage fcontext -a -t httpd_sys_rw_content_t ‘/opt/librenms/storage/framework/sessions(/.*)?’
restorecon -RFvv /opt/librenms/storage/framework/sessions
semanage fcontext -a -t httpd_sys_content_t ‘/opt/librenms/storage/framework/views(/.*)?’
semanage fcontext -a -t httpd_sys_rw_content_t ‘/opt/librenms/storage/framework/views(/.*)?’
restorecon -RFvv /opt/librenms/storage/framework/views
semanage fcontext -a -t httpd_sys_content_t ‘/opt/librenms/storage/framework/cache(/.*)?’
semanage fcontext -a -t httpd_sys_rw_content_t ‘/opt/librenms/storage/framework/cache(/.*)?’
restorecon -RFvv /opt/librenms/storage/framework/cache
tks one more time laf to reply.
Have you ran those commands?
I ran just the first ones, the others regarding to SELinux not, because I am using Centos7. Should I run these ones as well? because the message told us just to run if you are using SELinux.
Tks
I would double check and run “sestatus” in your terminal. it can come as part of a centos 7 installation
hum, great, tks for the clue, I didn’t know that, now I’ll run those commands here. Tks Chas.
