Hi , Everyone and master !!!
I’m newbie and now I wanna learn a librenms to monitoring arduino projects.
Unfortunately, I have a problem when installing it ini my raspberry Pi 3. Can u help me , please ??? Thanks
I’m guessing you aren’t following the official install docs.
You need to run ./scripts/composer_wrapper.sh install --no-dev like it says.
Okay thanks I’ll try
Can you please explain a bit more in detail. I am not sure what you mean by needing to run that command.
Anything I have tried does not work.
Can you explain “does not work”?
For example post the output you get when trying to run the command.
