Dear Team,
I have problem with device raisecom can’t monitor olt to onu port via snmp on librenms, anyone have solution for this ?
Please provide ALL info asked for here.
Dear Team,
Dear chorn.sam,
SNMP requires OIDs to increase hence the error. Your device is returning them out of order, which is a device bug. If I remember there is a net-snmp command line switch which allows out of order OIDs, but that opens you up to the possibility of infinite loops and other fun.
Sometimes, a wrong MIB (or a missing MIB) may create this issue. You should probably provide the requested details, and somebody may jump in and help you solve this.
While providing the snmpwalk
, you can add the -Cc
option to the line, to ensure all the walk is done without this “not increasing” issue.
As @murrant said, you may end up in a loop (with a very broken device) in which case you’ll have to interrupt the snmpwalk manually.
