LibreNMS | 21.6.0-8-g748186c05
DB Schema | 2021_03_11_003540_rename_toner_table (204)
PHP | 7.4.20
Python | 3.6.9
MySQL | 10.5.10-MariaDB-1:10.5.10+maria~bionic
RRDTool | 1.7.0
SNMP | NET-SNMP 5.7.3
[OK] Composer Version: 2.1.3
./lnms migrate
Hi, i’m stuck with this error:
In SchemaException.php line 86:
There is no column with name ‘toner_id’ on table ‘printer_supplies’.
Droped Printer_supplies table and recreated toner table, nothing changes.
I also run the table update procees manually
rename table toner to printer_supplies;
ALTER TABLE printer_supplies CHANGE toner_id supply_id INT UNSIGNED AUTO_INCREMENT NOT NULL;*
ALTER TABLE printer_supplies CHANGE toner_index supply_index INT NOT NULL;
ALTER TABLE printer_supplies CHANGE toner_type supply_type VARCHAR(64) NOT NULL;
ALTER TABLE printer_supplies CHANGE toner_oid supply_oid VARCHAR(64) NOT NULL;
ALTER TABLE printer_supplies CHANGE toner_descr supply_descr VARCHAR(32) DEFAULT ‘’ NOT NULL;
ALTER TABLE printer_supplies CHANGE toner_capacity supply_capacity INT DEFAULT 0 NOT NULL;
ALTER TABLE printer_supplies CHANGE toner_current supply_current INT DEFAULT 0 NOT NULL;
ALTER TABLE printer_supplies CHANGE toner_capacity_oid supply_capacity_oid VARCHAR(64) DEFAULT NULL;
ALTER TABLE printer_supplies CHANGE supply_descr supply_descr VARCHAR(255) CHARACTER SET utf8mb4 DEFAULT NULL COLLATE utf8mb4_unicode_ci;
MariaDB [librenms]> desc printer_supplies;
| Field | Type | Null | Key | Default | Extra |
| supply_id | int(10) unsigned | NO | PRI | NULL | auto_increment |
| device_id | int(10) unsigned | NO | MUL | 0 | |
| supply_index | int(11) | NO | | NULL | |
| supply_type | varchar(64) | NO | | NULL | |
| supply_oid | varchar(64) | NO | | NULL | |
| supply_descr | varchar(255) | YES | | NULL | |
| supply_capacity | int(11) | NO | | 0 | |
| supply_current | int(11) | NO | | 0 | |
| supply_capacity_oid | varchar(64) | YES | | NULL | |
The same error message is showed runing the migration.
There is any way to remove this table conversion from the process or something that i can do to complete the migration?
Thanks in advance!
