Had an issue on setup where the installer would hang and fail on creating DB Schema. Ran Validate.php and got this
[FAIL] Your database schema (10) is older than the latest (217).
[FIX] Manually run daily.sh, and check for any errors.
[WARN] You have not added any devices yet.
[FIX] You can add a device in the webui or with addhost.php
[OK] Composer Version: 1.8.0
[FAIL] Your database schema (262) is older than the latest (273).
Manually run ./daily.sh, and check for any errors.
You can add a device in the webui or with ./addhost.php
