I follow the tutorial to add custom graph for Alteon Radware.
Now I have a warning in Librenms saying :
Devices unpolled
It appears as though you have some devices that haven’t completed polling within the last 15 minutes, you may want to check that out
I execute the poll manualy in debug mode :
./poller.php -h @ip -d -m os -r -f
and I have the following error :
Librenms doesn’t found the RrdDefinition when I make
use LibreNMS\RRD\RrdDefinition
Thanks for your help
Is your install out of date?
./validate.php
Also, providing the code you are trying to run would be helpful.
Thanks for your quick responce.
yes the script ./validate.php generate 0 error.
The code is situate at includes/polling/os/radware.inc.php
<?php
$version = "Radware Alteonn " . preg_replace('/[\n\r"]+/','', snmp_get($device,".1.3.6.1.4.1.1872.2.5.1.3.1.30.0","-OQv"));
$hardware = preg_replace('/[\n\r"]+/', '', snmp_get($device,".1.3.6.1.2.1.1.1.0","-OQv"));
$serial = preg_replace('/[\n\r"]+/', '', snmp_get($device,".1.3.6.1.4.1.1872.2.5.1.3.1.18.0","-OQv"));
**use LibreNMS\RRD\RrdDefinition;**
$cpuSP = preg_replace('/[\n\r"]+/', '', snmp_get($device,'.1.3.6.1.4.1.1872.2.5.1.2.4.1.1.4.1','-OQv'));
if (is_numeric($cpuSP)) {
**$rrd_def = RrdDefinition::make()->addDataset('cpuSP', 'GAUGE', 0);**
$fields = array(
'cpuSP' => $cpuSP,
$tags = compact('rrd_def');
data_update($device, 'alteon_cpuSP', $tags, $fields);
$graphs['alteon_cpuSP'] = true;
$sessions = preg_replace('/[\n\r"]+/', '', snmp_get($device,'.1.3.6.1.4.1.1872.2.5.4.2.1.5.1.3.1','-OQv'));
if (is_numeric($sessions)) {
**$rrd_def = RrdDefinition::make()->addDataset('sessions', 'GAUGE', 0);**
$fields = array(
'sessions' => $sessions,
data_update($device, 'alteon_sessions', $tags, $fields);
$graphs['alteon_sessions'] = true;
@Perret_Bastien Do you have alteon_cpuSP.inc.php and alteon_sessions.inc.php located in the html/includes/graphs/device directory? Those should be the RRD definition files.
yes I have the script in the html/includes/graphs/device directory so I don’t understand
