For the last couple of days viewing the device page of an F5 load balancer is throwing and error.
[2020-05-01 11:17:24] production.ERROR: Call to undefined function LibreNMS\dbFetchRows() {"userId":1,"exception":"[object] (Symfony\\Component\\Debug\\Exception\\FatalThrowableError(code: 0): Call to undefined function LibreNMS\\dbFetchRows() at /opt/librenms/LibreNMS/Component.php:52)
[stacktrace]
#0 /opt/librenms/app/Http/Controllers/Device/Tabs/LoadBalancerController.php(56): LibreNMS\\Component->getComponentCount(1507)
#1 [internal function]: App\\Http\\Controllers\\Device\\Tabs\\LoadBalancerController->__construct()
This is the version information:
LibreNMS | 1.63-8-g954cb87e0
DB Schema | 2020_04_13_150500_add_last_error_fields_to_bgp_peers (164)
PHP | 7.2.24-0ubuntu0.18.04.4
MySQL | 10.1.44-MariaDB-0ubuntu0.18.04.1
RRDTool | 1.7.0
SNMP | NET-SNMP 5.7.3
It looks like something may have changed with the device tabs in the UI that doesn’t play nice with F5 device type in this commit maybe?
committed 12:25PM - 29 Apr 20 UTC
* Throw some shit together, rough outline.
* Reorganize tabs, use tab control… lers
* Implement performance (into the latency tab)
* Update resources/views/device/header.blade.php
Co-Authored-By: Jellyfrog <[email protected] >
* Add more tabs
* All controllers created
* Implement routes
* Implement smokeping
* routing and auth
* fix smokeping check
* Implement device dropdown menu
* Update deviceUrl to new style
* Use Gates
* Fix style
* use more appropriate gates
* add show-config gate
remove Laravel helper
* Only show vlan tab if VLANs exist for the device :D
* Fix rancid file check will return false
* revert over-zealous file name changes
* don't need to request the location parameter, just cast to string to avoid bugs when not found
* Move latency tab (ping/performance) to the position of performance instead of ping.
Co-authored-by: Jellyfrog <[email protected] >
Hope you can help. Thanks!
There is a bug for those, I’ve been working on fix, but the fix is a little bit of work.
Great, thanks! I did a bit of searching around and didn’t see anything so it’s good to know you are aware.
I am also having the same issue while viewing the graph of F5 devices.
production.ERROR: Call to undefined function LibreNMS\dbFetchRows() {“userId”:1,“exception”:"[object] (Symfony\Component\Debug\Exception\FatalThrowableError(code: 0): Call to undefined function LibreNMS\dbFetchRows() at /opt/librenms/LibreNMS/Component.php:52)
also facing this issue LibreNMS | 1.63-41-g25330646f
didnt see issue on this
Missed this message: Yes,… also having issues thinking it was the pip3/ redis error.
Also error for F5 devices. I posted: Some devices generate error page
TIA
Is it me or is there something wrong here ?:
(AM I specifying the wrong pr_id ?)
librenms@librenms:/opt/librenms$ ./scripts/github-apply 11527
Checking patch LibreNMS/Component.php…
Checking patch app/Http/Controllers/Widgets/TopDevicesController.php…
error: while searching for:
protected $defaults = [
‘title’ => null,
‘top_query’ => ‘traffic’,
‘sort_order’ => ‘asc’,
‘device_count’ => 5,
‘time_interval’ => 15,
‘device_group’ => null,
error: patch failed: app/Http/Controllers/Widgets/TopDevicesController.php:47
error: app/Http/Controllers/Widgets/TopDevicesController.php: patch does not apply
Checking patch app/Models/Component.php…
Checking patch app/Models/ComponentPref.php…
Checking patch app/Models/ComponentStatusLog.php…
Checking patch app/Models/DeviceAttrib.php…
Checking patch database/factories/ModelFactory.php…
Checking patch tests/Unit/ComponentTest.php…
librenms@librenms:/opt/librenms$ ./daily.sh
Updating Composer packages OK
Updated from 2533064 to c1c95ff OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
librenms@librenms:/opt/librenms$ ./validate.php
Component
Version
LibreNMS
1.63-42-gc1c95ffda
DB Schema
PHP
7.2.24-0ubuntu0.18.04.3
Python
3.6.9
MySQL
5.7.29-0ubuntu0.18.04.1
RRDTool
1.7.0
SNMP
NET-SNMP 5.7.3
[OK] Composer Version: 1.10.6
This is now merged, does the error still occur after running ./daily.sh
Did a ./daily.sh after the merge.
F5 device pages display correctly it seems now. Thanks.
I didn’t do the github-apply because it is merged of course.
