Hello I have followed this guide for setting up this server on Centos 7 and apache. I am getting the following when I go to the ip in the webserver
Error: Missing dependencies! Run the following command to fix:
when I try to run the script I get this
bash-4.2$ ./scripts/composer_wrapper.php install --no-dev
git checkout 609676a9f8d72da081c61f82967e1d16defc0c4e – /opt/librenms/vendor
fatal: Not a git repository (or any of the parent directories): .git
git reset HEAD /opt/librenms/vendor
Package operations: 58 installs, 0 updates, 0 removals
- Installing symfony/dotenv (v3.4.15): Downloading (failed)
Downloading (failed) Failed to download symfony/dotenv from dist: The “https://api.github.com/repos/symfony/dotenv/zipball/fcc8c8c73899e65ec528aac439c49e7929cdb87b” file could not be downloaded: SSL operation failed with code 1. OpenSSL Error messages:
error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed
Failed to enable crypto
failed to open stream: operation failed
Now trying to download from source - Installing symfony/dotenv (v3.4.15): Cloning fcc8c8c738
[RuntimeException]
Failed to clone https:// github. com/ symfony/ dotenv.git via https, ssh protocols, aborting.
https:// github. com /symfony /dotenv .git
fatal: unable to access ‘https:// github. com/symfony/ dotenv. git/’: Peer’s certificate issuer has bee
n marked as not trusted by the user. -
git @ github.com:symfony/dotenv.git
Permission denied (publickey).
fatal: Could not read from remote repository.Please make sure you have the correct access rights
and the repository exists.
install [–prefer-source] [–prefer-dist] [–dry-run] [–dev] [–no-dev] [–no-custom-installers] [–no-autoloader] [–no-scripts] [–no-progress] [–no-suggest] [-v|vv|vvv|–verbose] [-o|–optimize-autoloader] [-a|–classmap-authoritative] [–apcu-autoloader] [–ignore-platform-reqs] [–] []…
Can someone tell me how I can get this fixed pleased
Thanks in advanced
