Component | Version |
LibreNMS | 1.60-81-gcf023b9 |
DB Schema | 2020_02_10_223323_create_alert_location_map_table (159) |
PHP | 7.2.28-3+ubuntu16.04.1+deb.sury.org+1 |
MySQL | 10.0.38-MariaDB-0ubuntu0.16.04.1 |
RRDTool | 1.5.5 |
SNMP | NET-SNMP 5.7.3 |
Switched to distributed poller.
Added memcached, Redis and rrdcached.
It was all working until I restarted the poller service on the old “master” instance.
I got an infinite number of
Poller_0-6(ERROR):Poller poller exception! 'Redis' object has no attribute 'bzpopmin'
AttributeError: 'Redis' object has no attribute 'bzpopmin'
Traceback (most recent call last):
File "/opt/librenms/LibreNMS/queuemanager.py", line 54, in _service_worker
device_id = self.get_queue(queue_id).get(True, 10)
File "/opt/librenms/LibreNMS/__init__.py", line 323, in get
item = self._redis.bzpopmin(self.key, timeout=timeout)
Poller_0-12(ERROR):Poller poller exception! 'Redis' object has no attribute 'bzpopmin'
Poller_0-5(ERROR):Poller poller exception! 'Redis' object has no attribute 'bzpopmin'
And no device is polled, of course.
Redis is on the same host, configured .env as
REDIS_HOST=127.0.0.1
REDIS_PORT=6379
REDIS_DB=0
I can access the redis-cli and issue commands. Redis is 5.0.7.
This is the node that was running since months, the master and unique node.
The strange thing is that the poller node (with 2 devices) seems to work fine, connecting to mysql/redis/memcached on this same host.
I tried disabling distributed polling on main node in config but I don’t know why it requires this Redis thing now. I’m loosing important data and don’t mind to loose the distributed polling right now, but no way to go back to old config.
Please is there someone who can tell me how to disable the Redis requirement or, better, why it complains about a redis command that can be issued with no problem from the console?
