I have a running instance of LibreNMS on a ubuntu20.04. Without any particular reason (as far as I know), daily.sh suddenly stopped working.
When running manually I get the following:
./daily.sh: 34: source: not found
./daily.sh: 52: Syntax error: “(” unexpected (expecting “}”)
For the first, changing
source “${LIBRENMS_DIR}/.env”
into
. “${LIBRENMS_DIR}/.env”
solves the problem. But no idea why the second one fails. It’s on the following line:
args=("$@")
Output from validate.php:
Component | Version |
LibreNMS | 21.9.0-8-g0d499b538 |
DB Schema | 2021_08_26_093522_config_value_to_medium_text (217) |
PHP | 7.4.3 |
Python | 3.8.5 |
MySQL | 10.3.29-MariaDB-0ubuntu0.20.04.1 |
RRDTool | 1.7.2 |
SNMP | NET-SNMP 5.8 |
[OK] Composer Version: 1.8.6
[INFO] Detected Dispatcher Service
[FAIL] Dispatcher service is enabled on your cluster, but not in use on this node
[FAIL] Missing PHP extension: memcached
Please install memcached
[WARN] Could not check Python dependencies because this script is not running as librenms
Modified Files:
html/.htaccess
rrd/.gitignore
[FAIL] You need to run this script as ‘librenms’ or root
