I’ve been using LibreNMS for about a year to monitor ~30 devices in a production environment. It is fantastic but recently I have found a need for more detailed error reporting/tracking, such as Alignment Errors and FCS errors. I found in the global settings I can enable the Etherlike MIB which has OIDs for all the errors I want to track with this line:
enable_ports_etherlike 1
So now I can navigate to Devices > Ports > Etherlike, but all of the graphs are blank and show the -NaN- value for each OID. Not sure where to go from here in order to get these graphs to populate. Thanks in advance for any help/advice!
output of poller.php:
https://p.libren.ms/view/1797fd81
Validate.php:
| LibreNMS | 24.1.0-67-gd6ce29c05 (2024-02-06T09:42:36-06:00) |
| DB Schema | 2024_01_09_211518_custom_map_node_maplink (288) |
| PHP | 8.1.23 |
| Python | 3.10.12 |
| Database | MariaDB 10.6.16-MariaDB-0ubuntu0.22.04.1 |
| RRDTool | 1.7.2 |
| SNMP | 5.9.1 |
[OK] Composer Version: 2.6.6
Modified Files:
includes/definitions/discovery/nxos.yaml
