Hi there,
I’m monitoring a routeros wireless access point, and about every 6 hours, LibreNMS logs a dozen events about the signal being updated of various interfaces. These messages account for 95+% of the events for the device, crowding out other more useful messages.
I’ve tried ignoring the interfaces in the ports section of the device, setting the signal range to a High of 100, and Low of -200, disabling alerts for all of the respective interfaces, but nothing seems to stop LibreNMS from logging these messages. I expect their signals to change over time, that’s why I’m using LibreNMS in the first place. I just don’t want to be notified that the signal changed.
Here’s what I’m seeing:
Sensor Updated: signal routeros 16 wlan1b Signal
Sensor Updated: signal routeros 15 wlan2b Signal
AFAICT, the numbers (16 and 15) aren’t the signal strength, but possibly a LibreNMS id of some sort. The actual signals are in the -60 to -70 range. I think that’s it’s simply telling me that the values were updated, which isn’t particularly useful.
Thanks in advance.
