Eventlog errors: discovery + maintenance cleanup-syslog / cleanup-syslog
Hi all,
Recently, my LibreNMS Eventlog is showing errors:
discovery asw0-b2 Error discovering fdb-table module. Check log file for more details.
But there are no relevant logs:
root@librenms:~# grep -rl fdb-table /var/log/
root@librenms:~#
maintenance The scheduled command maintenance:cleanup-syslog failed to run. Check the maintenance.log for details.
Also, no relevant logs, and it works manually, well, at least no error, but nothing cleaned:
librenms@librenms:\~$ php artisan maintenance:cleanup-syslog
Cleared syslog entries older than 30 days (0 rows)
2026-01-12 03:48:00 maintenance The scheduled command maintenance:fetch-rss failed to run. Check the maintenance.log for details.
Also, cannot find any logs, and it works manually:
librenms@librenms:~$ php artisan maintenance:fetch-rss
[ Wed, 14 Jan 2026 14:27:29 +0000 ] LibreNMS https://www.librenms.org/notifications.rss (48)
[ Wed, 14 Jan 2026 14:27:29 +0000 ] local misc/notifications.rss (53)
[ Wed, 14 Jan 2026 14:27:29 +0000 ] Updating DB  Done
Here are maintenance logs:
librenms@librenms:~$ cat logs/maintenance.log
[ Wed, 14 Jan 2026 03:48:00 +0000 ] LibreNMS https://www.librenms.org/notifications.rss (48)
[ Wed, 14 Jan 2026 03:48:01 +0000 ] local misc/notifications.rss (53)
[ Wed, 14 Jan 2026 03:48:01 +0000 ] Updating DB  Done
maintenance.log       maintenance.log.1     maintenance.log.2.gz  maintenance.log.3.gz  maintenance.log.4.gz  maintenance.log.5.gz  maintenance.log.6.gz
librenms@librenms:~$ cat logs/maintenance.log.1
[ Tue, 13 Jan 2026 03:48:00 +0000 ] LibreNMS https://www.librenms.org/notifications.rss (48)
[ Tue, 13 Jan 2026 03:48:00 +0000 ] local misc/notifications.rss (53)
[ Tue, 13 Jan 2026 03:48:00 +0000 ] Updating DB  Done
Here is ./validate.php
LibreNMS  | 26.2.0-dev.6+bf2f15234 (2026-01-13T03:27:41+00:00)
DB Schema | 2025_12_05_205509_devices_add_mtu_status (362)
PHP       | 8.4.10
Python    | 3.10.12
Database  | MariaDB 10.6.22-MariaDB-0ubuntu0.22.04.1
SNMP      | 5.9.1
[OK]    Composer Version: 2.9.3
[OK]    Redis is unavailable
[OK]    rrd_dir is writable
Can anyone point me in the right direction?
Thanks,
C
i am also looking into some issues with the fdb-table module.
the logs are located in the Librenms install directory in /logs/librenms.logs
you have to look on the node that does the discovery if you have a distributed setup.
alternatively you can do at manual capture in the GUI while looking in librenms.log
in my logs i can see something like
[2026-01-26T08:04:15][ALERT] INFO: device:discover “some-device-name” (661) discovered in 38.809s
[2026-01-26T08:04:58][CRITICAL] Exception: Illuminate\Database\QueryException SQLSTATE[22007]: Invalid datetime format: 1366 Incorrect integer value: ‘’ for column librenms.ports_fdb.port_id at row 1 (Connection: mysql, Host: “some_IP_Address”, Port: 3306, Database: librenms, SQL: insert into ports_fdb (port_id, mac_address, vlan_id, device_id, created_at, updated_at) values (, bc8d1f60b747, 11128, 661, 2026-01-26 08:04:58, 2026-01-26 08:04:58)) @ /data/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php:838
hope it helps :slight_smile:
Thanks for this :slight_smile:
I have the same issue: SQLSTATE[22007]: Invalid datetime format: 1366 Incorrect integer value:
[2026-01-25T06:37:21][CRITICAL] Exception: Illuminate\Database\QueryException SQLSTATE[22007]: Invalid datetime format: 1366 Incorrect integer value: '' for column `librenms`.`ports_fdb`.`port_id` at row 1 (Connection: mysql, Host: localhost, Port: 3306, Database: librenms, SQL: insert into `ports_fdb` (`port_id`, `mac_address`, `vlan_id`, `device_id`, `created_at`, `updated_at`) values (, e83935254954, 2080, 5, 2026-01-25 06:37:21, 2026-01-25 06:37:21)) @ /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php:838
I’ll see if I can find anything on Google to fix this.
